[Geomoose-users] Annotation Layer
Johnson, Jeremy
JJohnson at ci.blaine.mn.us
Fri Oct 2 08:05:58 PDT 2015
I actually ended up using POLYGON instead of ANNOTATION and it worked perfectly. Thank you all for the help.
Jeremy Johnson
City of Blaine, GIS Coordinator
From: James Klassen [mailto:klassen.js at gmail.com]
Sent: Friday, October 02, 2015 9:49 AM
To: Johnson, Jeremy
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Annotation Layer
MapServer layer TYPE ANNOTATION was deprecated in MapServer 6.2 in favor of LABEL STYLES. However, the MapServer layer type has always only been loosely associated with the actual data type. (For example you can render a polygon layer as points and MapServer will just draw the vertices.)
So, I expect you would do something along the lines of setting TYPE POINT and then define a LABEL in your CLASS but no SYMBOL.
On Wed, Sep 30, 2015 at 2:17 PM, Johnson, Jeremy <JJohnson at ci.blaine.mn.us<mailto:JJohnson at ci.blaine.mn.us>> wrote:
I have downloaded the new MS4W with Geomoose install and have a quick question. I notice in the Mapserver documentation that the ANNOTATION type has been deprecated. I have a geodatabase that has an annotation layer of addresses that I have used in past installs, but I am getting a pink screen now. Anyone have any experience with getting GDB annotation layers to work with GeoMoose?
Thank you in advance.
Jeremy Johnson, GISP
GIS Coordinator
City of Blaine
(763) 717-2639<tel:%28763%29%20717-2639>
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20151002/265817c1/attachment.html>
More information about the Geomoose-users
