[Geomoose-users] WFS-T ideas
TC Haddad tchaddad at gmail.com
Fri Apr 22 10:38:59 PDT 2016
Hi Brent
Just briefly skimming the TinyOWS config options:
- XML: http://mapserver.org/tinyows/configfile.html#tinyows-configfile
- Mapfile: http://mapserver.org/tinyows/mapfileconfig.html
I don't see a place where you can confine editing to only a specific few
attributes. It seems like you make the layer editable or not (where editing
includes geometry and all attributes).
I don't know the WFS-T spec well enough to know if it is an option in the
spec that is just not implemented in TinyOWS, or what. Interesting
question, will try to look it up.
But anyhow, circling back to GeoMoose, if we wanted to find a way for a
user to "hide" fields from editing, it might have to be entirely on the GM
side if not supported by TinyOWS.
Tanya
On Fri, Apr 22, 2016 at 10:11 AM, Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Interesting stuff.  What did the layout of your attributes form end up
> looking like?  What would we need to address in GeoMOOSE to make it usable
> in a project like yours?
> Thanks!
> Best Regards,
> Brent Fraser
> On 4/21/2016 11:43 PM, Raffaele Morelli wrote:
>> On 21/04/16 at 05:21pm, Brent Fraser wrote:
>>> Hey all,
>>>    I've been experimenting with Geomoose's WFS-T (feature editing). Any
>>> thoughts about allowing teh target of the attribute editing to be a tab
>>> instead of just a dialog?
>> Recently I've been involved in a survey project, basically I was asked
>> to allow ~4500 users to insert points on a map and fill a form
>> (attributes).
>> Attributes form was "huge", ie ~15 select lists (with multiple choice)
>> and ~5 textbox, I
>> would have liked to use GeoMOOSE but WFT-T issues (those recently pointed
>> out to this ML)
>> and your point made me give up and switch to Drupal+Openlayers.
>> Must say I did not spent too much in digging into GM code for that
>> attribute thing
>> as my deadline was really close.
>> Ciao
>> /r
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160422/c9fc7e6d/attachment.html>
More information about the Geomoose-users mailing list
