[Geomoose-users] WFS-T ideas
Brent Fraser
bfraser at geoanalytic.com
Fri Apr 22 11:02:20 PDT 2016
Tanya,
There are a couple of things happening here with respect to
attributes. As a GeoMOOSE implementer, I can limit the attributes in
the Attribute Dialog by specifying only the ones I want to present to
the user in the <mapsource> definition in the mapbook:
<attribute name="geoid10" type="user" label="ID:"
default-value="27999"/>
<attribute name="namelsad10" type="user" label="Name:"/>
<attribute name="classfp10" type="select" label=" Type:
" default-value="C5">
<option value="C1">C1</option>
<option value="C5">C5</option>
</attribute>
even though there could be an additional 10 attribute fields in the
database for that feature type, the user will never see them. All good.
The other thing is a little odd. In my Iceberg application I have a
"created_time" that gets automatically populated by the Postgres
database engine:
created_time timestamp with time zone DEFAULT now(),
In my testing, TinyOWS was generating an error regarding time formats,
which was unexpected since I never listed the
created_time attribute in the mapsource. It appears TinyOWS gets all
the attributes by default. I was able to prevent this by adding a line
in the TinyOWS config.xml:
exclude_items="created_time,approved_time,deleted_time,obs_time"
Best Regards,
Brent Fraser
On 4/22/2016 11:38 AM, TC Haddad wrote:
> Hi Brent
> Just briefly skimming the TinyOWS config options:
> - XML: http://mapserver.org/tinyows/configfile.html#tinyows-configfile
> - Mapfile: http://mapserver.org/tinyows/mapfileconfig.html
> I don't see a place where you can confine editing to only a specific
> few attributes. It seems like you make the layer editable or not
> (where editing includes geometry and all attributes).
> I don't know the WFS-T spec well enough to know if it is an option in
> the spec that is just not implemented in TinyOWS, or what. Interesting
> question, will try to look it up.
> But anyhow, circling back to GeoMoose, if we wanted to find a way for
> a user to "hide" fields from editing, it might have to be entirely on
> the GM side if not supported by TinyOWS.
> Tanya
> On Fri, Apr 22, 2016 at 10:11 AM, Brent Fraser
> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
> Interesting stuff. What did the layout of your attributes form
> end up looking like? What would we need to address in GeoMOOSE to
> make it usable in a project like yours?
> Thanks!
> Best Regards,
> Brent Fraser
> On 4/21/2016 11:43 PM, Raffaele Morelli wrote:
> On 21/04/16 at 05:21pm, Brent Fraser wrote:
> Hey all,
> I've been experimenting with Geomoose's WFS-T (feature
> editing). Any
> thoughts about allowing teh target of the attribute
> editing to be a tab
> instead of just a dialog?
> Recently I've been involved in a survey project, basically I
> was asked
> to allow ~4500 users to insert points on a map and fill a form
> (attributes).
> Attributes form was "huge", ie ~15 select lists (with multiple
> choice) and ~5 textbox, I
> would have liked to use GeoMOOSE but WFT-T issues (those
> recently pointed out to this ML)
> and your point made me give up and switch to Drupal+Openlayers.
> Must say I did not spent too much in digging into GM code for
> that attribute thing
> as my deadline was really close.
> Ciao
> /r
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160422/c01c771f/attachment-0001.html>
More information about the Geomoose-users
