[Geomoose-users] WFS-T ideas
    Brent Fraser
    bfraser at geoanalytic.com
    Fri Apr 22 11:34:55 PDT 2016
Tanya,
   Lots of wanderings.  I ran across http://featureserver.org/ while
searching for a WFS-T server with more options for a data store back-end
(like Spatialite).  Looks like support has died out though...
Best Regards,
Brent Fraser
On 4/22/2016 12:06 PM, TC Haddad wrote:
> Awesome,
> "exclude_items" was just what I was interested in. Thanks!
> Interesting topics all of this. I'm very interested in your WFS-T
> wanderings, even though I don't currently have a project to apply them to.
> thanks for continuing to prompt,
> Tanya
> On Fri, Apr 22, 2016 at 11:02 AM, Brent Fraser
> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>     Tanya,
>       There are a couple of things happening here with respect to
>     attributes.  As a GeoMOOSE implementer, I can limit the attributes
>     in the Attribute Dialog by specifying only the ones I want to
>     present to the user in the <mapsource> definition in the mapbook:
>             <attribute name="geoid10"    type="user" label="ID:"
>     default-value="27999"/>
>             <attribute name="namelsad10" type="user" label="Name:"/>
>             <attribute name="classfp10" type="select" label=" Type: "
>     default-value="C5">
>                 <option value="C1">C1</option>
>                 <option value="C5">C5</option>
>             </attribute>
>     even though there could be an additional 10 attribute fields in
>     the database for that feature type, the user will never see them.
>     All good.
>     The other thing is a little odd.  In my Iceberg application I have
>     a "created_time" that gets automatically populated by the Postgres
>     database engine:
>     created_time timestamp with time zone DEFAULT now(),
>     In my testing, TinyOWS was generating an error regarding time
>     formats, which was unexpected since I never listed the
>     created_time attribute in the mapsource.  It appears TinyOWS gets
>     all the attributes by default.  I was able to prevent this by
>     adding a line in the TinyOWS config.xml:
>     exclude_items="created_time,approved_time,deleted_time,obs_time"
>     Best Regards,
>     Brent Fraser
>     On 4/22/2016 11:38 AM, TC Haddad wrote:
>>     Hi Brent
>>     Just briefly skimming the TinyOWS config options:
>>     - XML:
>>     http://mapserver.org/tinyows/configfile.html#tinyows-configfile
>>     - Mapfile: http://mapserver.org/tinyows/mapfileconfig.html
>>     I don't see a place where you can confine editing to only a
>>     specific few attributes. It seems like you make the layer
>>     editable or not (where editing includes geometry and all attributes).
>>     I don't know the WFS-T spec well enough to know if it is an
>>     option in the spec that is just not implemented in TinyOWS, or
>>     what. Interesting question, will try to look it up.
>>     But anyhow, circling back to GeoMoose, if we wanted to find a way
>>     for a user to "hide" fields from editing, it might have to be
>>     entirely on the GM side if not supported by TinyOWS.
>>     Tanya
>>     On Fri, Apr 22, 2016 at 10:11 AM, Brent Fraser
>>         Interesting stuff. What did the layout of your attributes
>>         form end up looking like?  What would we need to address in
>>         GeoMOOSE to make it usable in a project like yours?
>>         Thanks!
>>         Best Regards,
>>         Brent Fraser
>>         On 4/21/2016 11:43 PM, Raffaele Morelli wrote:
>>             On 21/04/16 at 05:21pm, Brent Fraser wrote:
>>                 Hey all,
>>                    I've been experimenting with Geomoose's WFS-T
>>                 (feature editing). Any
>>                 thoughts about allowing teh target of the attribute
>>                 editing to be a tab
>>                 instead of just a dialog?
>>             Recently I've been involved in a survey project,
>>             basically I was asked
>>             to allow ~4500 users to insert points on a map and fill a
>>             form (attributes).
>>             Attributes form was "huge", ie ~15 select lists (with
>>             multiple choice) and ~5 textbox, I
>>             would have liked to use GeoMOOSE but WFT-T issues (those
>>             recently pointed out to this ML)
>>             and your point made me give up and switch to
>>             Drupal+Openlayers.
>>             Must say I did not spent too much in digging into GM code
>>             for that attribute thing
>>             as my deadline was really close.
>>             Ciao
>>             /r
>>         _______________________________________________
>>         Geomoose-users mailing list
>>         Geomoose-users at lists.osgeo.org
>>         <mailto:Geomoose-users at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160422/d85ce5ef/attachment.html>
More information about the Geomoose-users
