[Geomoose-users] WFS-T ideas
Jim Klassen
klassen.js at gmail.com
Mon Apr 25 08:48:37 PDT 2016
An option for TinyOWS might be to do the attribute filtering in
PostgreSQL with some combination of views/triggers/rules. You probably
want to somehow enforce that clients can't view or update fields that
they shouldn't.
On 04/22/2016 01:34 PM, Brent Fraser wrote:
> Tanya,
> Lots of wanderings. I ran across http://featureserver.org/ while
> searching for a WFS-T server with more options for a data store
> back-end (like Spatialite). Looks like support has died out though...
> Best Regards,
> Brent Fraser
> On 4/22/2016 12:06 PM, TC Haddad wrote:
>> Awesome,
>> "exclude_items" was just what I was interested in. Thanks!
>> Interesting topics all of this. I'm very interested in your WFS-T
>> wanderings, even though I don't currently have a project to apply
>> them to.
>> thanks for continuing to prompt,
>> Tanya
>> On Fri, Apr 22, 2016 at 11:02 AM, Brent Fraser
>> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>> Tanya,
>> There are a couple of things happening here with respect to
>> attributes. As a GeoMOOSE implementer, I can limit the
>> attributes in the Attribute Dialog by specifying only the ones I
>> want to present to the user in the <mapsource> definition in the
>> mapbook:
>> <attribute name="geoid10" type="user" label="ID:"
>> default-value="27999"/>
>> <attribute name="namelsad10" type="user" label="Name:"/>
>> <attribute name="classfp10" type="select" label=" Type:
>> " default-value="C5">
>> <option value="C1">C1</option>
>> <option value="C5">C5</option>
>> </attribute>
>> even though there could be an additional 10 attribute fields in
>> the database for that feature type, the user will never see
>> them. All good.
>> The other thing is a little odd. In my Iceberg application I
>> have a "created_time" that gets automatically populated by the
>> Postgres database engine:
>> created_time timestamp with time zone DEFAULT now(),
>> In my testing, TinyOWS was generating an error regarding time
>> formats, which was unexpected since I never listed the
>> created_time attribute in the mapsource. It appears TinyOWS gets
>> all the attributes by default. I was able to prevent this by
>> adding a line in the TinyOWS config.xml:
>> exclude_items="created_time,approved_time,deleted_time,obs_time"
>> Best Regards,
>> Brent Fraser
>> On 4/22/2016 11:38 AM, TC Haddad wrote:
>>> Hi Brent
>>> Just briefly skimming the TinyOWS config options:
>>> - XML:
>>> http://mapserver.org/tinyows/configfile.html#tinyows-configfile
>>> - Mapfile: http://mapserver.org/tinyows/mapfileconfig.html
>>> I don't see a place where you can confine editing to only a
>>> specific few attributes. It seems like you make the layer
>>> editable or not (where editing includes geometry and all
>>> attributes).
>>> I don't know the WFS-T spec well enough to know if it is an
>>> option in the spec that is just not implemented in TinyOWS, or
>>> what. Interesting question, will try to look it up.
>>> But anyhow, circling back to GeoMoose, if we wanted to find a
>>> way for a user to "hide" fields from editing, it might have to
>>> be entirely on the GM side if not supported by TinyOWS.
>>> Tanya
>>> On Fri, Apr 22, 2016 at 10:11 AM, Brent Fraser
>>> <bfraser at geoanalytic.com> wrote:
>>> Interesting stuff. What did the layout of your attributes
>>> form end up looking like? What would we need to address in
>>> GeoMOOSE to make it usable in a project like yours?
>>> Thanks!
>>> Best Regards,
>>> Brent Fraser
>>> On 4/21/2016 11:43 PM, Raffaele Morelli wrote:
>>> On 21/04/16 at 05:21pm, Brent Fraser wrote:
>>> Hey all,
>>> I've been experimenting with Geomoose's WFS-T
>>> (feature editing). Any
>>> thoughts about allowing teh target of the attribute
>>> editing to be a tab
>>> instead of just a dialog?
>>> Recently I've been involved in a survey project,
>>> basically I was asked
>>> to allow ~4500 users to insert points on a map and fill
>>> a form (attributes).
>>> Attributes form was "huge", ie ~15 select lists (with
>>> multiple choice) and ~5 textbox, I
>>> would have liked to use GeoMOOSE but WFT-T issues (those
>>> recently pointed out to this ML)
>>> and your point made me give up and switch to
>>> Drupal+Openlayers.
>>> Must say I did not spent too much in digging into GM
>>> code for that attribute thing
>>> as my deadline was really close.
>>> Ciao
>>> /r
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> <mailto:Geomoose-users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
