[Geomoose-users] WFS-T ideas
Brent Fraser bfraser at geoanalytic.com
Fri Apr 22 13:25:07 PDT 2016
I like it!  It could open the door to more WPS services in GeoMOOSE...
Best Regards,
Brent Fraser
On 4/22/2016 12:46 PM, Jeff McKenna wrote:
> ZOO-Project (http://zoo-project.org/) can be setup to allow WFS-T
> through MapServer; what makes ZOO so attractive is that you can use
> any GDAL/OGR backend, so any database format supported by OGR. I
> really want to add ZOO-Project to MS4W (it's on my long list of tasks,
> ha) - but that will take a lot of effort, and I believe that some code
> changes must be contributed back into MapServer source, for everything
> to work with MapServer 7.  Anyway, I had already filed this as an
> enhancement ticket for MS4W, so I just thought I'd mention it here.  I
> do realize that ZOO-Project + GeoMOOSE might seem like overkill for
> just WFS-T at the moment, but, if ZOO-Project was already part of MS4W
> it would make more sense for you I bet.
> K, I'm rambling :)
> -jeff
> On 2016-04-22 3:34 PM, Brent Fraser wrote:
>> Tanya,
>>    Lots of wanderings.  I ran across http://featureserver.org/ while
>> searching for a WFS-T server with more options for a data store back-end
>> (like Spatialite).  Looks like support has died out though...
>> Best Regards,
>> Brent Fraser
>> On 4/22/2016 12:06 PM, TC Haddad wrote:
>>> Awesome,
>>> "exclude_items" was just what I was interested in. Thanks!
>>> Interesting topics all of this. I'm very interested in your WFS-T
>>> wanderings, even though I don't currently have a project to apply
>>> them to.
>>> thanks for continuing to prompt,
>>> Tanya
>>> On Fri, Apr 22, 2016 at 11:02 AM, Brent Fraser
>>> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>>>     Tanya,
>>>       There are a couple of things happening here with respect to
>>>     attributes.  As a GeoMOOSE implementer, I can limit the attributes
>>>     in the Attribute Dialog by specifying only the ones I want to
>>>     present to the user in the <mapsource> definition in the mapbook:
>>>             <attribute name="geoid10"    type="user" label="ID:"
>>>     default-value="27999"/>
>>>             <attribute name="namelsad10" type="user" label="Name:"/>
>>>             <attribute name="classfp10" type="select" label=" Type: "
>>>     default-value="C5">
>>>                 <option value="C1">C1</option>
>>>                 <option value="C5">C5</option>
>>>             </attribute>
>>>     even though there could be an additional 10 attribute fields in
>>>     the database for that feature type, the user will never see them.
>>>     All good.
>>>     The other thing is a little odd.  In my Iceberg application I have
>>>     a "created_time" that gets automatically populated by the Postgres
>>>     database engine:
>>>     created_time timestamp with time zone DEFAULT now(),
>>>     In my testing, TinyOWS was generating an error regarding time
>>>     formats, which was unexpected since I never listed the
>>>     created_time attribute in the mapsource.  It appears TinyOWS gets
>>>     all the attributes by default.  I was able to prevent this by
>>>     adding a line in the TinyOWS config.xml:
>>> exclude_items="created_time,approved_time,deleted_time,obs_time"
>>>     Best Regards,
>>>     Brent Fraser
>>>     On 4/22/2016 11:38 AM, TC Haddad wrote:
>>>>     Hi Brent
>>>>     Just briefly skimming the TinyOWS config options:
>>>>     - XML:
>>>> http://mapserver.org/tinyows/configfile.html#tinyows-configfile
>>>>     - Mapfile: http://mapserver.org/tinyows/mapfileconfig.html
>>>>     I don't see a place where you can confine editing to only a
>>>>     specific few attributes. It seems like you make the layer
>>>>     editable or not (where editing includes geometry and all
>>>> attributes).
>>>>     I don't know the WFS-T spec well enough to know if it is an
>>>>     option in the spec that is just not implemented in TinyOWS, or
>>>>     what. Interesting question, will try to look it up.
>>>>     But anyhow, circling back to GeoMoose, if we wanted to find a way
>>>>     for a user to "hide" fields from editing, it might have to be
>>>>     entirely on the GM side if not supported by TinyOWS.
>>>>     Tanya
>>>>     On Fri, Apr 22, 2016 at 10:11 AM, Brent Fraser
>>>> <<mailto:bfraser at geoanalytic.com>bfraser at geoanalytic.com> wrote:
>>>>         Interesting stuff. What did the layout of your attributes
>>>>         form end up looking like?  What would we need to address in
>>>>         GeoMOOSE to make it usable in a project like yours?
>>>>         Thanks!
>>>>         Best Regards,
>>>>         Brent Fraser
>>>>         On 4/21/2016 11:43 PM, Raffaele Morelli wrote:
>>>>             On 21/04/16 at 05:21pm, Brent Fraser wrote:
>>>>                 Hey all,
>>>>                    I've been experimenting with Geomoose's WFS-T
>>>>                 (feature editing). Any
>>>>                 thoughts about allowing teh target of the attribute
>>>>                 editing to be a tab
>>>>                 instead of just a dialog?
>>>>             Recently I've been involved in a survey project,
>>>>             basically I was asked
>>>>             to allow ~4500 users to insert points on a map and fill a
>>>>             form (attributes).
>>>>             Attributes form was "huge", ie ~15 select lists (with
>>>>             multiple choice) and ~5 textbox, I
>>>>             would have liked to use GeoMOOSE but WFT-T issues (those
>>>>             recently pointed out to this ML)
>>>>             and your point made me give up and switch to
>>>>             Drupal+Openlayers.
>>>>             Must say I did not spent too much in digging into GM code
>>>>             for that attribute thing
>>>>             as my deadline was really close.
>>>>             Ciao
>>>>             /r
>>>>         _______________________________________________
>>>>         Geomoose-users mailing list
>>>>         Geomoose-users at lists.osgeo.org
>>>>         <mailto:Geomoose-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
