[Geomoose-users] WFS-T ideas
TC Haddad
tchaddad at gmail.com
Mon Apr 25 09:43:09 PDT 2016
Couldn't you handle login at the Apache level?
TH
On Monday, April 25, 2016, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Jim,
> Interesting ideas. I had considered views (I use them extensively with
> the old GeoMOOSE editing) for other purposed like styling, but I didn't
> want to push my luck with TinyOWS. It is implied in the TinyOWS doc that
> it will work with views (I'll test that).
> The more bigger issue is security. With the old GeoMOOSE editing
> mechanism, I handled security in the PHP. It checked the session to ensure
> the user was logged in and issued the SQL if they were. I guess I'll need
> to code some PHP to act as a proxy between TinyOWS and GeoMOOSE.
> Remind me how is WFS-T better? ;)
> Best Regards,
> Brent Fraser
> On 4/25/2016 9:48 AM, Jim Klassen wrote:
>> An option for TinyOWS might be to do the attribute filtering in
>> PostgreSQL with some combination of views/triggers/rules. You probably
>> want to somehow enforce that clients can't view or update fields that
>> they shouldn't.
>> On 04/22/2016 01:34 PM, Brent Fraser wrote:
>>> Tanya,
>>> Lots of wanderings. I ran across http://featureserver.org/ while
>>> searching for a WFS-T server with more options for a data store
>>> back-end (like Spatialite). Looks like support has died out though...
>>> Best Regards,
>>> Brent Fraser
>>> On 4/22/2016 12:06 PM, TC Haddad wrote:
>>>> Awesome,
>>>> "exclude_items" was just what I was interested in. Thanks!
>>>> Interesting topics all of this. I'm very interested in your WFS-T
>>>> wanderings, even though I don't currently have a project to apply
>>>> them to.
>>>> thanks for continuing to prompt,
>>>> Tanya
>>>> On Fri, Apr 22, 2016 at 11:02 AM, Brent Fraser
>>>> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>>>> Tanya,
>>>> There are a couple of things happening here with respect to
>>>> attributes. As a GeoMOOSE implementer, I can limit the
>>>> attributes in the Attribute Dialog by specifying only the ones I
>>>> want to present to the user in the <mapsource> definition in the
>>>> mapbook:
>>>> <attribute name="geoid10" type="user" label="ID:"
>>>> default-value="27999"/>
>>>> <attribute name="namelsad10" type="user" label="Name:"/>
>>>> <attribute name="classfp10" type="select" label=" Type:
>>>> " default-value="C5">
>>>> <option value="C1">C1</option>
>>>> <option value="C5">C5</option>
>>>> </attribute>
>>>> even though there could be an additional 10 attribute fields in
>>>> the database for that feature type, the user will never see
>>>> them. All good.
>>>> The other thing is a little odd. In my Iceberg application I
>>>> have a "created_time" that gets automatically populated by the
>>>> Postgres database engine:
>>>> created_time timestamp with time zone DEFAULT now(),
>>>> In my testing, TinyOWS was generating an error regarding time
>>>> formats, which was unexpected since I never listed the
>>>> created_time attribute in the mapsource. It appears TinyOWS gets
>>>> all the attributes by default. I was able to prevent this by
>>>> adding a line in the TinyOWS config.xml:
>>>> exclude_items="created_time,approved_time,deleted_time,obs_time"
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 4/22/2016 11:38 AM, TC Haddad wrote:
>>>>> Hi Brent
>>>>> Just briefly skimming the TinyOWS config options:
>>>>> - XML:
>>>>> http://mapserver.org/tinyows/configfile.html#tinyows-configfile
>>>>> - Mapfile: http://mapserver.org/tinyows/mapfileconfig.html
>>>>> I don't see a place where you can confine editing to only a
>>>>> specific few attributes. It seems like you make the layer
>>>>> editable or not (where editing includes geometry and all
>>>>> attributes).
>>>>> I don't know the WFS-T spec well enough to know if it is an
>>>>> option in the spec that is just not implemented in TinyOWS, or
>>>>> what. Interesting question, will try to look it up.
>>>>> But anyhow, circling back to GeoMoose, if we wanted to find a
>>>>> way for a user to "hide" fields from editing, it might have to
>>>>> be entirely on the GM side if not supported by TinyOWS.
>>>>> Tanya
>>>>> On Fri, Apr 22, 2016 at 10:11 AM, Brent Fraser
>>>>> Interesting stuff. What did the layout of your attributes
>>>>> form end up looking like? What would we need to address in
>>>>> GeoMOOSE to make it usable in a project like yours?
>>>>> Thanks!
>>>>> Best Regards,
>>>>> Brent Fraser
>>>>> On 4/21/2016 11:43 PM, Raffaele Morelli wrote:
>>>>> On 21/04/16 at 05:21pm, Brent Fraser wrote:
>>>>> Hey all,
>>>>> I've been experimenting with Geomoose's WFS-T
>>>>> (feature editing). Any
>>>>> thoughts about allowing teh target of the attribute
>>>>> editing to be a tab
>>>>> instead of just a dialog?
>>>>> Recently I've been involved in a survey project,
>>>>> basically I was asked
>>>>> to allow ~4500 users to insert points on a map and fill
>>>>> a form (attributes).
>>>>> Attributes form was "huge", ie ~15 select lists (with
>>>>> multiple choice) and ~5 textbox, I
>>>>> would have liked to use GeoMOOSE but WFT-T issues (those
>>>>> recently pointed out to this ML)
>>>>> and your point made me give up and switch to
>>>>> Drupal+Openlayers.
>>>>> Must say I did not spent too much in digging into GM
>>>>> code for that attribute thing
>>>>> as my deadline was really close.
>>>>> Ciao
>>>>> /r
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> <mailto:Geomoose-users at lists.osgeo.org>
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160425/b806ab00/attachment-0001.html>
More information about the Geomoose-users
