[Geomoose-users] WFS-T ideas
Brent Fraser
bfraser at geoanalytic.com
Mon Apr 25 10:07:58 PDT 2016
Maybe, I'll have to study how Apache handles authentication...
Best Regards,
Brent Fraser
On 4/25/2016 10:43 AM, TC Haddad wrote:
> Couldn't you handle login at the Apache level?
> TH
> On Monday, April 25, 2016, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> Jim,
> Interesting ideas. I had considered views (I use them
> extensively with the old GeoMOOSE editing) for other purposed like
> styling, but I didn't want to push my luck with TinyOWS. It is
> implied in the TinyOWS doc that it will work with views (I'll test
> that).
> The more bigger issue is security. With the old GeoMOOSE
> editing mechanism, I handled security in the PHP. It checked the
> session to ensure the user was logged in and issued the SQL if
> they were. I guess I'll need to code some PHP to act as a proxy
> between TinyOWS and GeoMOOSE.
> Remind me how is WFS-T better? ;)
> Best Regards,
> Brent Fraser
> On 4/25/2016 9:48 AM, Jim Klassen wrote:
> An option for TinyOWS might be to do the attribute filtering in
> PostgreSQL with some combination of views/triggers/rules. You
> probably
> want to somehow enforce that clients can't view or update
> fields that
> they shouldn't.
> On 04/22/2016 01:34 PM, Brent Fraser wrote:
> Tanya,
> Lots of wanderings. I ran across
> http://featureserver.org/ while
> searching for a WFS-T server with more options for a data
> store
> back-end (like Spatialite). Looks like support has died
> out though...
> Best Regards,
> Brent Fraser
> On 4/22/2016 12:06 PM, TC Haddad wrote:
> Awesome,
> "exclude_items" was just what I was interested in. Thanks!
> Interesting topics all of this. I'm very interested in
> your WFS-T
> wanderings, even though I don't currently have a
> project to apply
> them to.
> thanks for continuing to prompt,
> Tanya
> On Fri, Apr 22, 2016 at 11:02 AM, Brent Fraser
> Tanya,
> There are a couple of things happening here
> with respect to
> attributes. As a GeoMOOSE implementer, I can
> limit the
> attributes in the Attribute Dialog by specifying
> only the ones I
> want to present to the user in the <mapsource>
> definition in the
> mapbook:
> <attribute name="geoid10" type="user"
> label="ID:"
> default-value="27999"/>
> <attribute name="namelsad10" type="user"
> label="Name:"/>
> <attribute name="classfp10" type="select"
> label=" Type:
> " default-value="C5">
> <option value="C1">C1</option>
> <option value="C5">C5</option>
> </attribute>
> even though there could be an additional 10
> attribute fields in
> the database for that feature type, the user will
> never see
> them. All good.
> The other thing is a little odd. In my Iceberg
> application I
> have a "created_time" that gets automatically
> populated by the
> Postgres database engine:
> created_time timestamp with time zone DEFAULT
> now(),
> In my testing, TinyOWS was generating an error
> regarding time
> formats, which was unexpected since I never
> listed the
> created_time attribute in the mapsource. It
> appears TinyOWS gets
> all the attributes by default. I was able to
> prevent this by
> adding a line in the TinyOWS config.xml:
> exclude_items="created_time,approved_time,deleted_time,obs_time"
> Best Regards,
> Brent Fraser
> On 4/22/2016 11:38 AM, TC Haddad wrote:
> Hi Brent
> Just briefly skimming the TinyOWS config options:
> - XML:
> http://mapserver.org/tinyows/configfile.html#tinyows-configfile
> - Mapfile:
> http://mapserver.org/tinyows/mapfileconfig.html
> I don't see a place where you can confine
> editing to only a
> specific few attributes. It seems like you
> make the layer
> editable or not (where editing includes
> geometry and all
> attributes).
> I don't know the WFS-T spec well enough to
> know if it is an
> option in the spec that is just not
> implemented in TinyOWS, or
> what. Interesting question, will try to look
> it up.
> But anyhow, circling back to GeoMoose, if we
> wanted to find a
> way for a user to "hide" fields from editing,
> it might have to
> be entirely on the GM side if not supported
> by TinyOWS.
> Tanya
> On Fri, Apr 22, 2016 at 10:11 AM, Brent Fraser
> <bfraser at geoanalytic.com> wrote:
> Interesting stuff. What did the layout
> of your attributes
> form end up looking like? What would we
> need to address in
> GeoMOOSE to make it usable in a project
> like yours?
> Thanks!
> Best Regards,
> Brent Fraser
> On 4/21/2016 11:43 PM, Raffaele Morelli
> wrote:
> On 21/04/16 at 05:21pm, Brent Fraser
> wrote:
> Hey all,
> I've been experimenting with
> Geomoose's WFS-T
> (feature editing). Any
> thoughts about allowing teh
> target of the attribute
> editing to be a tab
> instead of just a dialog?
> Recently I've been involved in a
> survey project,
> basically I was asked
> to allow ~4500 users to insert points
> on a map and fill
> a form (attributes).
> Attributes form was "huge", ie ~15
> select lists (with
> multiple choice) and ~5 textbox, I
> would have liked to use GeoMOOSE but
> WFT-T issues (those
> recently pointed out to this ML)
> and your point made me give up and
> switch to
> Drupal+Openlayers.
> Must say I did not spent too much in
> digging into GM
> code for that attribute thing
> as my deadline was really close.
> Ciao
> /r
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160425/ca6810bd/attachment.html>
More information about the Geomoose-users
