[Geomoose-users] Geomoose and mapcache
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Dec 9 09:58:09 PST 2016
Brent,
I was in the middle of writing this e-mail when I got interrupted so I couldn’t finish it earlier. Anyways it sounds like you have everything figured out. Just in case, here are a couple tips that I would recommend. Let me know if you need anything else.
1) make sure your tile size, extent and resolutions / scales match between mapcache and the geomoose mapbook.
2) Here is the workflow on how data is drawn in mapcache, at least this is what we do...
a) You need to configure MapServer to serve WMS.
b) Mapcache needs to consume the WMS Service This is done in the <source> section of mapcache
c) Eventually you will need to set up a gridset if you are using a custom projection. I would hold off on this until you can actually see your data using the built in gridset data.
c) You will need to create a tileset in Mapcache that is a combination of the <source> and a <gridset> as well as other things such as the image format etc.
d) GeoMOOSE then can connect to mapcache via WMS, or other service...
Sincerely,
Mark Volz, GISP
-----Original Message-----
From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Friday, December 09, 2016 10:25 AM
To: Jeff McKenna <jmckenna at gatewaygeomatics.com>; GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] Geomoose and mapcache
Hey Jeff,
So far so good. I've been able to edit the httpd.conf file (for some reason I had C:C: in my mapcache paths), restart Apache, and click on the Demo link under MapCache URLs heading in the http://localhost page of MS4W. The page showed me the demo data in the available tiling schemes. Took me a while to figure out the HTML did not exist on disk as mapcache was generating these demo pages.
The next step will be a little more difficult as I need to configure MapCache and GeoMoose to show my data. We should consider shipping our demo data with a pre-configured mapcache mapsource, or at least adding a page in our doc on it.
And many thanks for including mapcache in MS4W!
Best Regards,
Brent Fraser
On 12/9/2016 5:52 AM, Jeff McKenna wrote:
> Hi Brent,
> Also as you travel down that path let me know if you think any tweaks
> are needed into the distributed "/apps/mapcache/mapcache.xml" file in
> MS4W.
> -jeff
> On 2016-12-08 10:33 PM, Brent Fraser wrote:
>> Hi all,
>> I thought I would learn how to use mapcache. Does any one have any
>> example snippets from a mapbook.xml and mapcache's config.xml?
>> Thanks!
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
