[Geomoose-users] Geomoose and mapcache
Brent Fraser bfraser at geoanalytic.com
Fri Dec 9 10:44:32 PST 2016
Mark,
   Many thanks for this.  My Googling showed that you had blazed the
trail a few years ago when mapcache first appeared; very brave.
Best Regards,
Brent Fraser
On 12/9/2016 10:58 AM, Mark Volz wrote:
> Brent,
> I was in the middle of writing this e-mail when I got interrupted so I couldn’t finish it earlier.  Anyways it sounds like you have everything figured out.  Just in case, here are a couple tips that I would recommend.  Let me know if you need anything else.
> 1) make sure your tile size, extent and resolutions / scales match between mapcache and the geomoose mapbook.
> 2) Here is the workflow on how data is drawn in mapcache, at least this is what we do...
> a) You need to configure MapServer to serve WMS.
> b) Mapcache needs to consume the WMS Service  This is done in the <source> section of mapcache
> c) Eventually you will need to set up a gridset if you are using a custom projection.  I would hold off on this until you can actually see your data using the built in gridset data.
> c) You will need to create a tileset in Mapcache that is a combination of the <source> and a <gridset> as well as other things such as the image format etc.
> d) GeoMOOSE then can connect to mapcache via WMS, or other service...
> Sincerely,
> Mark Volz, GISP
> -----Original Message-----
> From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
> Sent: Friday, December 09, 2016 10:25 AM
> To: Jeff McKenna <jmckenna at gatewaygeomatics.com>; GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> Subject: Re: [Geomoose-users] Geomoose and mapcache
> Hey Jeff,
>     So far so good.  I've been able to edit the httpd.conf file (for some reason I had C:C: in my mapcache paths), restart Apache, and click on the Demo link under MapCache URLs heading  in the http://localhost page of MS4W.  The page showed me the demo data in the available tiling schemes.  Took me a while to figure out the HTML did not exist on disk as mapcache was generating these demo pages.
>     The next step will be a little more difficult as I need to configure MapCache and GeoMoose to show my data.  We should consider shipping our demo data with a pre-configured mapcache mapsource, or at least adding a page in our doc on it.
>     And many thanks for including mapcache in MS4W!
> Best Regards,
> Brent Fraser
> On 12/9/2016 5:52 AM, Jeff McKenna wrote:
>> Hi Brent,
>> Also as you travel down that path let me know if you think any tweaks
>> are needed into the distributed "/apps/mapcache/mapcache.xml" file in
>> MS4W.
>> -jeff
>> On 2016-12-08 10:33 PM, Brent Fraser wrote:
>>> Hi all,
>>>    I thought I would learn how to use mapcache.  Does any one have any
>>> example snippets from a mapbook.xml and mapcache's config.xml?
>>> Thanks!
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
