[Geomoose-users] DigitalGlobe API
TC Haddad
tchaddad at gmail.com
Fri Dec 23 18:26:57 PST 2016
Thanks for posting - just tested this and it seems to work very nicely.
On Fri, Dec 23, 2016 at 10:20 AM, Kevin Grootendorst <
kgrootendorst at gmail.com> wrote:
> Hello list,
> I wanted to share with you how I integrated a free Digital Globe API into
> GeoMoose. For some, this may not be relevant or that complicated, however,
> I'm hoping it may help someone in our community.
> First, sign up for your own free API key: https://platform.digitalglobe.
> com/maps-api/#plans. The free api gives you 20,000 views of the imagery.
> Second, incorporate the following map sources into your mapbook.xml file:
> <map-source name="DG_Sat" type="xyz">
> <layer name="Maps API Recent Imagery DigitalGlobe, Inc." />
> <url>http://api.tiles.mapbox.com/v4/digitalglobe.nal0g75k/$
> {z}/${x}/${y}.png?access_token=YOUR API KEY</url>
> <param name="FORMAT" value="png"/>
> <param name="attribution" value="Copyright DigitalGlobe, Inc"/>
> </map-source>
> <map-source name="DG_Hybrid" type="xyz">
> <layer name="Maps API Recent Imagery with Streets DigitalGlobe,
> Inc." />
> <url>http://api.tiles.mapbox.com/v4/digitalglobe.nal0mpda/$
> </map-source>
> In the above examples replace 'YOUR API KEY' with the actual key code.
> Third, add these to the <catalog> section in the mapbook.xml file:
> <layer title="DigitalGlobe Inc. Recent Imagery" src="DG_Sat/Maps API
> Recent Imagery DigitalGlobe, Inc." show-legend="false" legend="false"
> fade="false" unfade="false"/>
> <layer title="DigitalGlobe Inc. Recent Imagery with Streets"
> src="DG_Hybrid/Maps API Recent Imagery with Streets DigitalGlobe, Inc."
> show-legend="false" legend="false" fade="false" unfade="false"/>
> In these examples, I'm showing both the recent imagery and recent imagery
> with streets layers.
> You can also add a terrain map and streetmap vectors too.
> Cheers,
> Kevin
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161223/aeeccb74/attachment.html>
More information about the Geomoose-users
