[Geomoose-users] DigitalGlobe API
James Klassen
klassen.js at gmail.com
Fri Dec 23 19:14:10 PST 2016
Yes, very cool. We should probably make a spot on the github wiki to
document tips like this one.
On Dec 23, 2016 20:27, "TC Haddad" <tchaddad at gmail.com> wrote:
> Thanks for posting - just tested this and it seems to work very nicely.
> On Fri, Dec 23, 2016 at 10:20 AM, Kevin Grootendorst <
> kgrootendorst at gmail.com> wrote:
>> Hello list,
>> I wanted to share with you how I integrated a free Digital Globe API into
>> GeoMoose. For some, this may not be relevant or that complicated, however,
>> I'm hoping it may help someone in our community.
>> First, sign up for your own free API key: https://platform.digitalglobe.
>> com/maps-api/#plans. The free api gives you 20,000 views of the imagery.
>> Second, incorporate the following map sources into your mapbook.xml file:
>> <map-source name="DG_Sat" type="xyz">
>> <layer name="Maps API Recent Imagery DigitalGlobe, Inc." />
>> <url>http://api.tiles.mapbox.com/v4/digitalglobe.nal0g75k/${
>> z}/${x}/${y}.png?access_token=YOUR API KEY</url>
>> <param name="FORMAT" value="png"/>
>> <param name="attribution" value="Copyright DigitalGlobe, Inc"/>
>> </map-source>
>> <map-source name="DG_Hybrid" type="xyz">
>> <layer name="Maps API Recent Imagery with Streets
>> <url>http://api.tiles.mapbox.com/v4/digitalglobe.nal0mpda/${
>> </map-source>
>> In the above examples replace 'YOUR API KEY' with the actual key code.
>> Third, add these to the <catalog> section in the mapbook.xml file:
>> <layer title="DigitalGlobe Inc. Recent Imagery" src="DG_Sat/Maps API
>> Recent Imagery DigitalGlobe, Inc." show-legend="false" legend="false"
>> fade="false" unfade="false"/>
>> <layer title="DigitalGlobe Inc. Recent Imagery with Streets"
>> src="DG_Hybrid/Maps API Recent Imagery with Streets DigitalGlobe, Inc."
>> show-legend="false" legend="false" fade="false" unfade="false"/>
>> In these examples, I'm showing both the recent imagery and recent imagery
>> with streets layers.
>> You can also add a terrain map and streetmap vectors too.
>> Cheers,
>> Kevin
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161223/8a252c9f/attachment-0001.html>
More information about the Geomoose-users
