[Geomoose-users] startup service
Brent Fraser
bfraser at geoanalytic.com
Tue May 17 20:16:52 PDT 2016
Seems to work. I'll test again tomorrow with the new fixes to the
startup logic.
Best Regards,
Brent Fraser
On 5/17/2016 7:14 PM, Dan Little wrote:
> It may solve the problem but I can't promise that I've done a lot of
> testing with non-default settings. YMMV.
> On Sun, May 15, 2016 at 6:07 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>> Dan,
>> Now that the startup_service specified in the mapbook or config.js works
>> (or at least it should; I'm still having problems getting any of the three
>> startup methods to work using yesterday's nightly build), I expect my
>> original problem would still exist: the toolbar will be disabled.
>> I did notice this in the GeoMOOSE doc
>> (http://docs.geomoose.org/2.8/docs/configuration.html#configuration):
>> services.disable_others
>> Toggle whether tools and other tabs should be disabled when starting a
>> service.
>> I wonder if this would solve my problem of having a startup service with no
>> user input needed?
>> Best Regards,
>> Brent Fraser
>> On 3/29/2016 2:10 PM, Dan Little wrote:
>> The disabling of the toolbar is actually a new usability 'feature.' One of
>> the big struggles that both Jim and Eli found in the UI was the order of
>> operations when multiple services were starting at the same time due to the
>> 'open' nature of the toolbar operation. You can see this in operation in
>> the current demo when you click the "Search Parcels" tab. The only way to
>> get the toolbar back is to click "cancel" which allows the service to clean
>> itself up properly.
>> If you've got a specific tab that you want displayed all the time it may be
>> necessary to write it as a custom-tab extension. Which in 2.9 is going to
>> get a bit easier.
>> On Tue, Mar 22, 2016 at 3:49 PM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> Hi devs,
>>> In my task to upgrade my digitizing app, I see a couple of things:
>>> 1. That specifying a startup service in the URL disables the tools in
>>> the toolbar
>>> 2. Specifying a startup service in the mapbook or in config.js doesn't
>>> seem to work. And I can't find any place in the code where startup_service
>>> is referenced.
>>> So I added a few lines to main.js (at line 73):
>>> var params = GeoMOOSE.getUrlParameters();
>>> if(GeoMOOSE.isDefined(params.call)) {
>>> var service_name = params.call;
>>> delete params.call;
>>> GeoMOOSE.startService(service_name, params, true);
>>> /* --- new: --- */
>>> if(GeoMOOSE.isDefined(CONFIGURATION['startup_service'])) {
>>> var service_name = CONFIGURATION['startup_service'];
>>> while it does start the service in the config.js, but it has the same
>>> effect on the toolbar as specifying "?call=myservice" in the URL (it is
>>> disabled).
>>> Is there something special I need to set to enable the toolbar after a
>>> startup service?
>>> Best Regards,
>>> Brent Fraser
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20160517/7921f8cc/attachment.html>
More information about the Geomoose-users
