[Geomoose-users] Multiple Mapbook.xml
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Wed Nov 16 13:51:07 PST 2016
Kevin,
In that case, you should take a look at the PHP handler script (config.php) in GeoMOOSE for calling the .XML file. you can change that up for handling the different Mapbooks as needed. the locations in the codebase that you have listed are where you would start in order to be able to run multiple MapBooks.
I wonder if it makes sense to put in a request to add this into the GeoMOOSE Demo.
bobb
On Nov 16, 2016, at 3:39 PM, Kevin Grootendorst <kgrootendorst at gmail.com<mailto:kgrootendorst at gmail.com>> wrote:
Thanks for the feedback Bob.
I was going to use a login php script to get users to a dedicated html page. That page will have dedicated URLs pointing to unique GeoMoose applications.
So simpler than your approach I think.
Kevin
On Wed, Nov 16, 2016 at 4:32 PM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us<mailto:bob.basques at ci.stpaul.mn.us>> wrote:
Hi Kevin,
We’ve been running multiple MapBooks for a while now, but we don’t use PHP, we instead were using PERL, and more recently Ruby to handle the separations. A big piece of the equation will be how you are going to manage the user list? Will the Mapbooks be used in a self service manner, as in people can pick which one they want to use, or are you going to uselogin, etc.
bobb
On Nov 16, 2016, at 1:59 PM, Kevin Grootendorst <kgrootendorst at gmail.com<mailto:kgrootendorst at gmail.com>> wrote:
Hello users, I'm looking to create multiple GeoMoose sites within the same GeoMoose installation.
I see that Mapbook.xml is referenced by 'settings.ini' which in turn is referenced by 'config.php'.
I would like to be able to have User A hit Mapbook_A.xml, User B hit Mapbook_B.xml, etc.
Can anyone shed light on how to accomplish this. I didn't notice anything in the documentation(?).
Using GeoMoose 2.8.1.
Thanks, Kevin
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
"This telephone has too many shortcomings to be seriously considered as a means of communication. The device is inherently of no value to us." -- An internal Western Union memo, 1876
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161116/6b405a9e/attachment-0001.html>
More information about the Geomoose-users
