[Geomoose-users] Multiple Mapbook.xml
Kevin Grootendorst kgrootendorst at gmail.com
Thu Nov 17 06:44:25 PST 2016
Thanks Eli, this method generally works, but there is one small hiccup.  I
think there must be an open session somewhere because the wrong mapbook is
sometimes called.
For example, if User A opens the mapbook for User A, all is fine. If User A
opens the mapbook for User B, again, all is fine (a different mapbook is
displayed).  However is User A then tries to open the mapbook for User A
again, the mapbook for User B is mistakenly called and displayed.  Does
that make sense?  Maybe I need to end a session somewhere.
On Wed, Nov 16, 2016 at 8:05 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> Hi Kevin,
> There is this old documentation you can look at.  It might not be relevant
> anymore.  I've never used multiple mapbooks.
> http://www.geomoose.org/wiki/index.php/Modification_to_Use_
> Multiple_Map_Books
> Best regards, Eli
> On Wed, Nov 16, 2016 at 1:39 PM, Kevin Grootendorst <
> kgrootendorst at gmail.com> wrote:
>> Thanks for the feedback Bob.
>> I was going to use a login php script to get users to a dedicated html
>> page.  That page will have dedicated URLs pointing to unique GeoMoose
>> applications.
>> So simpler than your approach I think.
>> Kevin
>> On Wed, Nov 16, 2016 at 4:32 PM, Basques, Bob (CI-StPaul) <
>> bob.basques at ci.stpaul.mn.us> wrote:
>>> Hi Kevin,
>>> We’ve been running multiple MapBooks for a while now, but we don’t use
>>> PHP, we instead were using PERL, and more recently Ruby to handle the
>>> separations.  A big piece of the equation will be how you are going to
>>> manage the user list?  Will the Mapbooks be used in a self service manner,
>>> as in people can pick which one they want to use, or are you going to
>>> uselogin, etc.
>>> bobb
>>> On Nov 16, 2016, at 1:59 PM, Kevin Grootendorst <kgrootendorst at gmail.com>
>>> wrote:
>>> Hello users, I'm looking to create multiple GeoMoose sites within the
>>> same GeoMoose installation.
>>> I see that Mapbook.xml is referenced by 'settings.ini' which in turn is
>>> referenced by 'config.php'.
>>> I would like to be able to have User A hit Mapbook_A.xml, User B hit
>>> Mapbook_B.xml, etc.
>>> Can anyone shed light on how to accomplish this.  I didn't notice
>>> anything in the documentation(?).
>>> Using GeoMoose 2.8.1.
>>> Thanks, Kevin
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>> "This telephone has too many shortcomings to be seriously considered as
>>> a means of communication. The device is inherently of no value to us."  --
>>> An internal Western Union memo, 1876
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161117/bfdf161b/attachment.html>
More information about the Geomoose-users mailing list
