[Geomoose-users] Identify with a https WMS source
James Klassen
klassen.js at gmail.com
Mon Feb 6 12:19:08 PST 2017
MapServer doesn't care. If Apache (or other web server of choice) serves
https that is all you need. If you are specifying the *_online_resource
metadata, be sure to include the https there. If you don't specify it and
MapServer guesses right as is, it will autodetect if it is being queried
over https (at least with Apache) and respond accordingly (again only
effects the online_resource links in GetCapabilities responses).
On Feb 6, 2017 12:53 PM, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
> slightly off-topic: This is more of a MapServer question but relates
> to GeoMoose as a client too. Can MapServer serve WMS/WFS over https?
> I've not found it in the docs or email lists (but my searching may be
> at fault).
> Best regards, Eli
> On Mon, Feb 6, 2017 at 10:39 AM, Jeff McKenna
> <jmckenna at gatewaygeomatics.com> wrote:
> > Hi Brent,
> > MS4W includes an important file for this, the CA certificate bundle, and
> > Apache's httpd.conf points to it (see
> > http://ms4w.com/README_INSTALL.html#k-certificates-
> for-https-with-wms-wfs-servers).
> > However sometimes MS4W gets upgraded and that little file is forgotten in
> > the release package (I believe this was missing in MS4W 3.1.4); the file
> is
> > included in the recent MS4W 3.2.0 release. But if you ever notice
> anything
> > missing in an MS4W, please file a ticket right away on that at
> > http://ms4w.com/trac (otherwise that little file will be missed in the
> next
> > release).
> > -jeff
> > On 2017-02-05 10:45 PM, Brent Fraser wrote:
> >> Hi all,
> >> To get identify.php to work when I specify a WMS map-source using
> >> https (instead of the old and out-dated http), I had to add a couple of
> >> curl options to identify.php around line 196:
> >> curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
> >> curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
> >> Should I file an issue or is this already handled in 3.0?
> >> And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into
> >> the request? Should we make that configurable in the map-source
> >> definition?
> >> Thanks!
> > Jeff McKenna
> > MapServer Consulting and Training Services
> > http://www.gatewaygeomatics.com/
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170206/51a7d416/attachment.html>
More information about the Geomoose-users
