[Geomoose-users] Identify with a https WMS source
Eli Adam eadam at co.lincoln.or.us
Mon Feb 6 10:53:08 PST 2017
slightly off-topic: This is more of a MapServer question but relates
to GeoMoose as a client too.  Can MapServer serve WMS/WFS over https?
I've not found it in the docs or email lists (but my searching may be
at fault).
Best regards, Eli
On Mon, Feb 6, 2017 at 10:39 AM, Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> Hi Brent,
> MS4W includes an important file for this, the CA certificate bundle, and
> Apache's httpd.conf points to it (see
> http://ms4w.com/README_INSTALL.html#k-certificates-for-https-with-wms-wfs-servers).
> However sometimes MS4W gets upgraded and that little file is forgotten in
> the release package (I believe this was missing in MS4W 3.1.4); the file is
> included in the recent MS4W 3.2.0 release.  But if you ever notice anything
> missing in an MS4W, please file a ticket right away on that at
> http://ms4w.com/trac (otherwise that little file will be missed in the next
> release).
> -jeff
> On 2017-02-05 10:45 PM, Brent Fraser wrote:
>> Hi all,
>>   To get identify.php to work when I specify a WMS map-source using
>> https (instead of the old and out-dated http), I had to add a couple of
>> curl options to identify.php around line 196:
>>         curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
>>         curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
>> Should I file an issue or is this already handled in 3.0?
>> And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into
>> the request?  Should we make that configurable in the map-source
>> definition?
>> Thanks!
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
