[Geomoose-users] Identify with a https WMS source
James Klassen
klassen.js at gmail.com
Mon Feb 6 14:49:46 PST 2017
If your GeoMoose (or other web map) is hosted on https but you are
displaying tiles or WMS maps over http, the browser will complain
(sometimes quietly) that the page isn't secure because some elements of the
page were loaded over http and could have possibly be tampered with (say to
insert javascript).
Not necessarily a GeoMoose proper concern, but I also have sites that are
enforcing https so they can use the geolocation API. Thus those sites also
require tiles/WMS over https.
My experience with (MapServer) WMS over https is it works without issue for
both web maps and the usual desktop applications.
On Feb 6, 2017 2:28 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
> Eli,
> Yes it can. I don't recall doing anything special to mapserver or
> mapcache to enable https. And all Geomoose needs is a map-source url
> starting with https.
> Best Regards,
> Brent Fraser
> On 2/6/2017 11:53 AM, Eli Adam wrote:
>> slightly off-topic: This is more of a MapServer question but relates
>> to GeoMoose as a client too. Can MapServer serve WMS/WFS over https?
>> I've not found it in the docs or email lists (but my searching may be
>> at fault).
>> Best regards, Eli
>> On Mon, Feb 6, 2017 at 10:39 AM, Jeff McKenna
>> <jmckenna at gatewaygeomatics.com> wrote:
>>> Hi Brent,
>>> MS4W includes an important file for this, the CA certificate bundle, and
>>> Apache's httpd.conf points to it (see
>>> http://ms4w.com/README_INSTALL.html#k-certificates-for-
>>> https-with-wms-wfs-servers).
>>> However sometimes MS4W gets upgraded and that little file is forgotten in
>>> the release package (I believe this was missing in MS4W 3.1.4); the file
>>> is
>>> included in the recent MS4W 3.2.0 release. But if you ever notice
>>> anything
>>> missing in an MS4W, please file a ticket right away on that at
>>> http://ms4w.com/trac (otherwise that little file will be missed in the
>>> next
>>> release).
>>> -jeff
>>> On 2017-02-05 10:45 PM, Brent Fraser wrote:
>>>> Hi all,
>>>> To get identify.php to work when I specify a WMS map-source using
>>>> https (instead of the old and out-dated http), I had to add a couple of
>>>> curl options to identify.php around line 196:
>>>> curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
>>>> curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
>>>> Should I file an issue or is this already handled in 3.0?
>>>> And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into
>>>> the request? Should we make that configurable in the map-source
>>>> definition?
>>>> Thanks!
>>> Jeff McKenna
>>> MapServer Consulting and Training Services
>>> http://www.gatewaygeomatics.com/
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170206/9062a27e/attachment.html>
More information about the Geomoose-users
