[Geomoose-users] Metadata link
Jim Klassen
klassen.js at gmail.com
Wed Jan 25 07:14:08 PST 2017
2.9.3 or 2.9.2? http://demo.geomoose.org/2.9/ should be at 2.9.2 right
now. http://demo.geomoose.org/master/ will likely become 2.9.3 when ready.
On 01/25/2017 08:37 AM, Dan Little wrote:
> The CSS changes should be included in the 2.9.3 package.
> I just verified on http://demo.geomoose.org/2.9/
> You'll need to add the following to your site.css file...
> .spite-control.sprite-control-metadata {
> /* style the metadata icon */
> .catalog-layer-controls {
> display: inline-block;
> .catalog-layer-titlebar {
> On Wed, Jan 25, 2017 at 8:11 AM, Kevin Grootendorst
> <kgrootendorst at gmail.com <mailto:kgrootendorst at gmail.com>> wrote:
> Dan - I noticed this ticket is now closed. Does this mean that it
> will be a part of the 2.9.3 release? I'm not familiar with GitHub.
> Our client is requesting the metadata link beside the layer name,
> with an option to have a meaningful icon for the link.
> Thanks,
> Kevin
> On Wed, Jan 11, 2017 at 4:33 PM, Dan Little
> <theduckylittle at gmail.com <mailto:theduckylittle at gmail.com>> wrote:
> I just went through that code and it looks like we may have
> deprecated
> the configuration option of putting the layer controls next to the
> layer title.
> And when I looked to do a CSS hack I realized that we don't
> have good
> class names there either!
> I created this ticket to address that problem:
> - https://github.com/geomoose/geomoose/issues/162
> <https://github.com/geomoose/geomoose/issues/162>
> I'm going to try and get it done today but it may not make it into
> 2.9.1 as I don't know if Jim started work on the release yet.
> On Wed, Jan 11, 2017 at 11:48 AM, Kevin Grootendorst
> > Thanks Bob and Dan for the responses.
> > Dan - I'm okay with having all layer tools next to the layer
> title. In fact,
> > I will only have the metadata link tool anyway in this
> application.
> > Can you elaborate on the code change(s) needed to implement
> this change?
> > Thanks.
> > Kevin
> > On Wed, Jan 11, 2017 at 12:26 PM, Dan Little
> > wrote:
> >> You can also override the CSS for that particular tool to
> change the
> >> look. Changing the position is a bit more difficult
> because we have a
> >> lot of the DOM work done in Javascript in ways that aren't
> easily
> >> subclassed or overridden.
> >> Moving the metadata tool next to the layer title will move
> ALL of the
> >> layer tools next to the layer title.
> >> On Wed, Jan 11, 2017 at 9:06 AM, Basques, Bob (CI-StPaul)
> >> <bob.basques at ci.stpaul.mn.us
> <mailto:bob.basques at ci.stpaul.mn.us>> wrote:
> >> > Kevin,
> >> > I believe that icon is part of the GeoMOOSE icon sprite
> image. (one
> >> > image
> >> > for all the icons)
> >> > You should be able to see the raw image (with all the
> icons) in it by
> >> > right-clicking on the binocular icon and viewing the
> background image.
> >> > I
> >> > did this with firefox to display the image that the icons
> are sourced
> >> > from.
> >> > You can either replace the icon sprite image with one of
> your own or I
> >> > believe you can substitute individual icon images in the
> mapbook, but
> >> > I’ve
> >> > not done this in quite a while myself, so someone else
> will need to
> >> > chime in
> >> > on how that’s done in the latest versions. I do know
> that the more
> >> > images
> >> > you introduce, the slower the interface will be when loading.
> >> > bobb
> >> > On Jan 10, 2017, at 6:12 PM, Kevin Grootendorst
> >> > wrote:
> >> > Dear list,
> >> > I would like to add a metadata link beside certain layers
> in my catalog.
> >> > I
> >> > see from the demo that a link can easily be added. I
> would like to
> >> > customize the location of the link icon, and also the
> icon itself.
> >> > In the attached graphic, I've enabled metadata for the
> layer 'DEM Tile
> >> > Index'. However, the icon used for it is a set of
> binoculars and the
> >> > link
> >> > is located beneath the layer. I would like to
> re-position the link to
> >> > be
> >> > beside the layer name and use a different icon.
> >> > Can someone point me to the file that contains this item
> so that I can
> >> > customize? I can't seem to locate it.
> >> > I found this site which incorporates these changes:
> >> > http://geomoose.lyonco.org/geomoose/lyonMaindemo.html
> <http://geomoose.lyonco.org/geomoose/lyonMaindemo.html>
> >> > Thanks.
> >> > Kevin
> <Metadata_link.PNG>_______________________________________________
> >> > Geomoose-users mailing list
> >> > Geomoose-users at lists.osgeo.org
> <mailto:Geomoose-users at lists.osgeo.org>
> >> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
> <http://lists.osgeo.org/mailman/listinfo/geomoose-users>
> >> > "I've had a wonderful time, but this wasn't it." -
> Groucho Marx
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170125/29ee1d93/attachment-0001.html>
More information about the Geomoose-users
