[Geomoose-users] How To Add Search Clarification
    Dan Little
    theduckylittle at gmail.com
    Tue Sep  5 06:05:52 PDT 2017
Another fix for today. :D
Yes, you can use both at the same time.  There's no conflict in leaving the
*layer* in the catalog that displays the search as the WMS-based version
but the WFS configuration will need to be added next to it to add search
capabilities.
On Fri, Sep 1, 2017 at 11:47 AM, Reynolds, Michael J. (MNIT) <
mike.reynolds at state.mn.us> wrote:
> I notice in the following How To doc:
> https://github.com/geomoose/gm3/blob/master/docs/howto/add-search.md
> It describes creating a map-source name="firestations-wfs".
> Then later we're adding a new search service, specifically:
> searchLayers: ['firestations/fire_stations'],
> Is that correct or should it be
> searchLayers: ['firestations-wfs/fire_stations']
> On another note, we'd like to use a search service on a mapserver layer
> that uses png images for each point and labels.  We see that search service
> is currently a wfs or mapserver-wfs thing and we're wondering if there's
> any way to mashup the two and get the best of both worlds.  Even if the wfs
> layer isn't styled at all but used to execute the search and the search
> service in turn makes sure the related mapserver wms layer is also on.
> Pair/mash/link?
> Thank you.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170905/707b607c/attachment.html>
More information about the Geomoose-users
