[Geomoose-users] How To Add Search Clarification
TC Haddad
tchaddad at gmail.com
Tue Sep 5 06:52:31 PDT 2017
Is it correct to say that both WMS and WFS versions should be together In a
mapserver group ? That is the example in the demo, though the docs don't
state it's required from what I saw...
On Tue, Sep 5, 2017 at 6:05 AM Dan Little <theduckylittle at gmail.com> wrote:
> Another fix for today. :D
> Yes, you can use both at the same time. There's no conflict in leaving
> the *layer* in the catalog that displays the search as the WMS-based
> version but the WFS configuration will need to be added next to it to add
> search capabilities.
> On Fri, Sep 1, 2017 at 11:47 AM, Reynolds, Michael J. (MNIT) <
> mike.reynolds at state.mn.us> wrote:
>> I notice in the following How To doc:
>> https://github.com/geomoose/gm3/blob/master/docs/howto/add-search.md
>> It describes creating a map-source name="firestations-wfs".
>> Then later we're adding a new search service, specifically:
>> searchLayers: ['firestations/fire_stations'],
>> Is that correct or should it be
>> searchLayers: ['firestations-wfs/fire_stations']
>> On another note, we'd like to use a search service on a mapserver layer
>> that uses png images for each point and labels. We see that search service
>> is currently a wfs or mapserver-wfs thing and we're wondering if there's
>> any way to mashup the two and get the best of both worlds. Even if the wfs
>> layer isn't styled at all but used to execute the search and the search
>> service in turn makes sure the related mapserver wms layer is also on.
>> Pair/mash/link?
>> Thank you.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170905/00fc1240/attachment.html>
More information about the Geomoose-users
