[Geomoose-users] How To Add Search Clarification
Dan Little
theduckylittle at gmail.com
Wed Sep 6 05:10:13 PDT 2017
Unfortunately, you need to have two <map-source> entries at this point.
One for the WMS service and one for the WFS service.
The search tool gets configured to point to the WFS <map-source> and the
catalog item is pointed towards the WMS <map-source>.
On Tue, Sep 5, 2017 at 8:52 AM, TC Haddad <tchaddad at gmail.com> wrote:
> Is it correct to say that both WMS and WFS versions should be together In
> a mapserver group ? That is the example in the demo, though the docs don't
> state it's required from what I saw...
> On Tue, Sep 5, 2017 at 6:05 AM Dan Little <theduckylittle at gmail.com>
> wrote:
>> Another fix for today. :D
>> Yes, you can use both at the same time. There's no conflict in leaving
>> the *layer* in the catalog that displays the search as the WMS-based
>> version but the WFS configuration will need to be added next to it to add
>> search capabilities.
>> On Fri, Sep 1, 2017 at 11:47 AM, Reynolds, Michael J. (MNIT) <
>> mike.reynolds at state.mn.us> wrote:
>>> I notice in the following How To doc:
>>> https://github.com/geomoose/gm3/blob/master/docs/howto/add-search.md
>>> It describes creating a map-source name="firestations-wfs".
>>> Then later we're adding a new search service, specifically:
>>> searchLayers: ['firestations/fire_stations'],
>>> Is that correct or should it be
>>> searchLayers: ['firestations-wfs/fire_stations']
>>> On another note, we'd like to use a search service on a mapserver layer
>>> that uses png images for each point and labels. We see that search service
>>> is currently a wfs or mapserver-wfs thing and we're wondering if there's
>>> any way to mashup the two and get the best of both worlds. Even if the wfs
>>> layer isn't styled at all but used to execute the search and the search
>>> service in turn makes sure the related mapserver wms layer is also on.
>>> Pair/mash/link?
>>> Thank you.
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170906/24db6ee4/attachment.html>
More information about the Geomoose-users
