[Geomoose-users] GM3 identify items in SpatiaLite db?
TC Haddad
tchaddad at gmail.com
Mon Dec 10 06:49:00 PST 2018
Does anyone have a successful GM3 example of enabling Identify on items in
a SpatiaLite db?
I have a working example in GM2 that I am trying to transfer to GM3, and
everything I've tried is failing.
The layer draws just fine, and there are no significant error messages,
just no results.
Layer def and Mapbook snippet below, SpatiaLite db was created in QGIS 2.18.
---------------- fwd ---------------- >>
LAYER
NAME 'points'
CONNECTIONTYPE ogr
CONNECTION "\data\points.sqlite"
DATA "points"
STATUS ON
TYPE POINT
PROJECTION
'init=epsg:3857'
END
METADATA
'ows_title' 'points'
'ows_include_items' 'all'
'gml_include_items' 'all'
END
LABELCACHE ON
LABELITEM 'SERVICELOC'
TEMPLATE 'foo.html'
CLASS
NAME "Service Locations"
STYLE
SYMBOL "square"
SIZE 8.0
OUTLINECOLOR 0 0 0
COLOR 0 0 255
END
LABEL
TYPE TRUETYPE
FONT vera_sans
SIZE 8
ANTIALIAS TRUE
WRAP ' '
COLOR 0 0 255
OUTLINECOLOR 255 255 255
BUFFER 4
MINFEATURESIZE auto
PARTIALS FALSE
POSITION uc
END
END
TOLERANCE 30
END
<map-source name="points" type="mapserver">
<file>points.map</file>
<layer name="points" status="off">
<template name="identify"><![CDATA[
<div>
<div style="background-color:Gainsboro">
<b>Points</b>
</div>
<div class="item">
<label>Location Number:</label> {{
properties.LocNumber }}
</div>
<div class="item">
<label>Location Street:</label> {{
properties.LocStreet }}
</div>
</div>
]]></template>
</layer>
<param name="FORMAT" value="image/png;bits=8"/>
</map-source>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181210/2aac935d/attachment.html>
More information about the Geomoose-users
