[Geomoose-users] GM3 identify items in SpatiaLite db?
James Klassen
klassen.js at gmail.com
Mon Dec 10 09:12:38 PST 2018
One thing to check is if the case of the properties. Different formats
have different conventions about lower/mixed/uppercase for the
properties/field names.
If you look at the response to the GetFeatureInfo request is it showing
data?
Another thing if you aren't using the standard GeoMoose includes, you might
be missing the metadata block to enable all the WMS/WFS request types.
On Mon, Dec 10, 2018 at 8:49 AM TC Haddad <tchaddad at gmail.com> wrote:
> Does anyone have a successful GM3 example of enabling Identify on items in
> a SpatiaLite db?
> I have a working example in GM2 that I am trying to transfer to GM3, and
> everything I've tried is failing.
> The layer draws just fine, and there are no significant error messages,
> just no results.
> Layer def and Mapbook snippet below, SpatiaLite db was created in QGIS
> 2.18.
> ---------------- fwd ---------------- >>
> LAYER
> NAME 'points'
> CONNECTIONTYPE ogr
> CONNECTION "\data\points.sqlite"
> DATA "points"
> STATUS ON
> TYPE POINT
> PROJECTION
> 'init=epsg:3857'
> END
> METADATA
> 'ows_title' 'points'
> 'ows_include_items' 'all'
> 'gml_include_items' 'all'
> END
> LABELCACHE ON
> LABELITEM 'SERVICELOC'
> TEMPLATE 'foo.html'
> CLASS
> NAME "Service Locations"
> STYLE
> SYMBOL "square"
> SIZE 8.0
> OUTLINECOLOR 0 0 0
> COLOR 0 0 255
> END
> LABEL
> TYPE TRUETYPE
> FONT vera_sans
> SIZE 8
> ANTIALIAS TRUE
> WRAP ' '
> COLOR 0 0 255
> OUTLINECOLOR 255 255 255
> BUFFER 4
> MINFEATURESIZE auto
> PARTIALS FALSE
> POSITION uc
> END
> END
> TOLERANCE 30
> END
> <map-source name="points" type="mapserver">
> <file>points.map</file>
> <layer name="points" status="off">
> <template name="identify"><![CDATA[
> <div>
> <div style="background-color:Gainsboro">
> <b>Points</b>
> </div>
> <div class="item">
> <label>Location Number:</label> {{
> properties.LocNumber }}
> </div>
> <div class="item">
> <label>Location Street:</label> {{
> properties.LocStreet }}
> </div>
> </div>
> ]]></template>
> </layer>
> <param name="FORMAT" value="image/png;bits=8"/>
> </map-source>
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181210/3fc24ecf/attachment-0001.html>
More information about the Geomoose-users
