[Geomoose-users] GM3 identify items in SpatiaLite db?
TC Haddad
tchaddad at gmail.com
Mon Dec 10 09:36:16 PST 2018
Thanks, I think I am ok on the GM includes, but will play with the field
name case. Everything I've seen says SQLite/SpatiaLite is
case-insensitive...
The GetFeatureInfo response is showing some sort of return, but it is not
intelligible.
Other things I've tried:
- identifying the same data in GeoPacakge (identify fails in the same way),
and
- ESRI PGDB (identify succeeds, which is frustrating!)
On Mon, Dec 10, 2018 at 9:12 AM James Klassen <klassen.js at gmail.com> wrote:
> One thing to check is if the case of the properties. Different formats
> have different conventions about lower/mixed/uppercase for the
> properties/field names.
> If you look at the response to the GetFeatureInfo request is it showing
> data?
> Another thing if you aren't using the standard GeoMoose includes, you
> might be missing the metadata block to enable all the WMS/WFS request types.
> On Mon, Dec 10, 2018 at 8:49 AM TC Haddad <tchaddad at gmail.com> wrote:
>> Does anyone have a successful GM3 example of enabling Identify on items
>> in a SpatiaLite db?
>> I have a working example in GM2 that I am trying to transfer to GM3, and
>> everything I've tried is failing.
>> The layer draws just fine, and there are no significant error messages,
>> just no results.
>> Layer def and Mapbook snippet below, SpatiaLite db was created in QGIS
>> 2.18.
>> ---------------- fwd ---------------- >>
>> LAYER
>> NAME 'points'
>> CONNECTIONTYPE ogr
>> CONNECTION "\data\points.sqlite"
>> DATA "points"
>> STATUS ON
>> TYPE POINT
>> PROJECTION
>> 'init=epsg:3857'
>> END
>> METADATA
>> 'ows_title' 'points'
>> 'ows_include_items' 'all'
>> 'gml_include_items' 'all'
>> END
>> LABELCACHE ON
>> LABELITEM 'SERVICELOC'
>> TEMPLATE 'foo.html'
>> CLASS
>> NAME "Service Locations"
>> STYLE
>> SYMBOL "square"
>> SIZE 8.0
>> OUTLINECOLOR 0 0 0
>> COLOR 0 0 255
>> END
>> LABEL
>> TYPE TRUETYPE
>> FONT vera_sans
>> SIZE 8
>> ANTIALIAS TRUE
>> WRAP ' '
>> COLOR 0 0 255
>> OUTLINECOLOR 255 255 255
>> BUFFER 4
>> MINFEATURESIZE auto
>> PARTIALS FALSE
>> POSITION uc
>> END
>> END
>> TOLERANCE 30
>> END
>> <map-source name="points" type="mapserver">
>> <file>points.map</file>
>> <layer name="points" status="off">
>> <template name="identify"><![CDATA[
>> <div>
>> <div style="background-color:Gainsboro">
>> <b>Points</b>
>> </div>
>> <div class="item">
>> <label>Location Number:</label> {{
>> properties.LocNumber }}
>> </div>
>> <div class="item">
>> <label>Location Street:</label> {{
>> properties.LocStreet }}
>> </div>
>> </div>
>> ]]></template>
>> </layer>
>> <param name="FORMAT" value="image/png;bits=8"/>
>> </map-source>
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181210/0fca35f6/attachment.html>
More information about the Geomoose-users
