[Geomoose-users] GM3 identify items in SpatiaLite db?
Jim Klassen klassen.js at gmail.com
Mon Dec 10 12:35:02 PST 2018
GetFeatureInfo doesn't take any query parameters that are case
sensitive, but it's response contains field names.  GeoMoose cares about
the case of those field names matching the template (in the mapbook) and
any other place they are used.  Different data sources to MapServer have
different defaults for how they handle the case of field names.
For example, in the mapbook (or GeoMoose remote template):
{{ properties.pin }} is not the same as {{ properties.PIN }} and to work
it must match the field name as it is returned by MapServer.  If it
doesn't, the field will be shown as "???".
On 12/10/18 12:48 PM, TC Haddad wrote:
> Thanks - I'll experiment a bit more. Case doesn't seem to be having an
> impact.
> What's confusing is that the GetFeatureInfo request doesn't use
> anything that would be case-sensitive, and my map file is set to
> return all fields, regardless of field name.
> On Mon, Dec 10, 2018 at 9:45 AM James Klassen <klassen.js at gmail.com
> <mailto:klassen.js at gmail.com>> wrote:
>     I tried changing the demo parcels layer to GeoPackage with ogr2ogr
>     and it worked for me.
>     I also I tried SpatiaLite, but identify returned ???? for all the
>     fields.   I suspect this is a case issue, but I didn't have time
>     to check if changing the case in template would fix it.
>     SpatiaLite might be case insensitive itself but it does present a
>     case to MapServer and then MapServer passes that onto GeoMoose.
>     MapServer and GeoMoose are both case sensitive.
>     On Mon, Dec 10, 2018, 11:36 TC Haddad <tchaddad at gmail.com
>     <mailto:tchaddad at gmail.com> wrote:
>         Thanks, I think I am ok on the GM includes, but will play with
>         the field name case. Everything I've seen says
>         SQLite/SpatiaLite is case-insensitive...
>         The GetFeatureInfo response is showing some sort of return,
>         but it is not intelligible.
>         Other things I've tried:
>         - identifying the same data in GeoPacakge (identify fails in
>         the same way), and
>         - ESRI PGDB (identify succeeds, which is frustrating!)
>         On Mon, Dec 10, 2018 at 9:12 AM James Klassen
>         <klassen.js at gmail.com <mailto:klassen.js at gmail.com>> wrote:
>             One thing to check is if the case of the properties.
>             Different formats have different conventions about
>             lower/mixed/uppercase for the properties/field names.
>             If you look at the response to the GetFeatureInfo request
>             is it showing data?
>             Another thing if you aren't using the standard GeoMoose
>             includes, you might be missing the metadata block to
>             enable all the WMS/WFS request types.
>             On Mon, Dec 10, 2018 at 8:49 AM TC Haddad
>             <tchaddad at gmail.com <mailto:tchaddad at gmail.com>> wrote:
>                 Does anyone have a successful GM3 example of enabling
>                 Identify on items in a SpatiaLite db?
>                 I have a working example in GM2 that I am trying to
>                 transfer to GM3, and everything I've tried is failing.
>                 The layer draws just fine, and there are no
>                 significant error messages, just no results.
>                 Layer def and Mapbook snippet below, SpatiaLite db was
>                 created in QGIS 2.18.
>                 ---------------- fwd ---------------- >>
>                     LAYER
>                         NAME 'points'
>                         CONNECTIONTYPE ogr
>                         CONNECTION "\data\points.sqlite"
>                         DATA "points"
>                         STATUS ON
>                         TYPE POINT
>                         PROJECTION
>                             'init=epsg:3857'
>                         END
>                         METADATA
>                             'ows_title' 'points'
>                             'ows_include_items' 'all'
>                             'gml_include_items' 'all'
>                         END
>                         LABELCACHE ON
>                         LABELITEM 'SERVICELOC'
>                         TEMPLATE 'foo.html'
>                         CLASS
>                             NAME "Service Locations"
>                                STYLE
>                                  SYMBOL "square"
>                                  SIZE 8.0
>                                  OUTLINECOLOR 0 0 0
>                                  COLOR 0 0 255
>                                END
>                                     LABEL
>                                         TYPE TRUETYPE
>                                         FONT vera_sans
>                                         SIZE 8
>                                         ANTIALIAS TRUE
>                                         WRAP ' '
>                                         COLOR 0 0 255
>                                         OUTLINECOLOR 255 255 255
>                                         BUFFER 4
>                                         MINFEATURESIZE auto
>                                         PARTIALS FALSE
>                                         POSITION uc
>                                     END
>                         END
>                         TOLERANCE 30
>                     END
>                     <map-source name="points" type="mapserver">
>                         <file>points.map</file>
>                         <layer name="points" status="off">
>                         <template name="identify"><![CDATA[
>                                 <div>
>                                     <div
>                 style="background-color:Gainsboro">
>                                     <b>Points</b>
>                                     </div>
>                                     <div class="item">
>                                         <label>Location
>                 Number:</label> {{ properties.LocNumber }}
>                                     </div>
>                                     <div class="item">
>                                         <label>Location
>                 Street:</label> {{ properties.LocStreet }}
>                                     </div>
>                                 </div>
>                                 ]]></template>
>                         </layer>
>                         <param name="FORMAT" value="image/png;bits=8"/>
>                     </map-source>
>                 _______________________________________________
>                 Geomoose-users mailing list
>                 Geomoose-users at lists.osgeo.org
>                 <mailto:Geomoose-users at lists.osgeo.org>
>                 https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181210/2d5c2b51/attachment-0001.html>
More information about the Geomoose-users mailing list
