[Geomoose-users] GM3 identify items in SpatiaLite db?
TC Haddad
tchaddad at gmail.com
Tue Dec 11 12:18:27 PST 2018
Yeah - I was thinking it might be at the OGR level?
I was going to look and see if OGR had a field-name cleaning option that I
could use to clean up the file via command line beforehand, so that I don't
run into this again...
On Tue, Dec 11, 2018 at 9:41 AM Jim Klassen <klassen.js at gmail.com> wrote:
> Wow, that was a tricky one.
> You might want to pass on the illegal field name issue to MapServer as I
> suspect it should be transforming the field names to output valid GML.
> On 12/10/2018 05:32 PM, TC Haddad wrote:
> Got it, thanks for the help!
> After much flailing, it turned out to be an illegal field name buried deep
> in the file (137 fields, and one name included a period, ugh). This meant
> that the GML being returned was malformed, and GeoMoose couldn't even parse
> it.
> Once past that error, the hint about case sensitivity became relevant,
> because as soon as the GML was parsable, it would not populate the template
> until the case of the field names matched.
> thanks again!
> On Mon, Dec 10, 2018 at 12:35 PM Jim Klassen <klassen.js at gmail.com> wrote:
>> GetFeatureInfo doesn't take any query parameters that are case sensitive,
>> but it's response contains field names. GeoMoose cares about the case of
>> those field names matching the template (in the mapbook) and any other
>> place they are used. Different data sources to MapServer have different
>> defaults for how they handle the case of field names.
>> For example, in the mapbook (or GeoMoose remote template):
>> {{ properties.pin }} is not the same as {{ properties.PIN }} and to work
>> it must match the field name as it is returned by MapServer. If it
>> doesn't, the field will be shown as "???".
>> On 12/10/18 12:48 PM, TC Haddad wrote:
>> Thanks - I'll experiment a bit more. Case doesn't seem to be having an
>> impact.
>> What's confusing is that the GetFeatureInfo request doesn't use anything
>> that would be case-sensitive, and my map file is set to return all fields,
>> regardless of field name.
>> On Mon, Dec 10, 2018 at 9:45 AM James Klassen <klassen.js at gmail.com>
>> wrote:
>>> I tried changing the demo parcels layer to GeoPackage with ogr2ogr and
>>> it worked for me.
>>> I also I tried SpatiaLite, but identify returned ???? for all the
>>> fields. I suspect this is a case issue, but I didn't have time to check
>>> if changing the case in template would fix it.
>>> SpatiaLite might be case insensitive itself but it does present a case
>>> to MapServer and then MapServer passes that onto GeoMoose. MapServer and
>>> GeoMoose are both case sensitive.
>>> On Mon, Dec 10, 2018, 11:36 TC Haddad <tchaddad at gmail.com wrote:
>>>> Thanks, I think I am ok on the GM includes, but will play with the
>>>> field name case. Everything I've seen says SQLite/SpatiaLite is
>>>> case-insensitive...
>>>> The GetFeatureInfo response is showing some sort of return, but it is
>>>> not intelligible.
>>>> Other things I've tried:
>>>> - identifying the same data in GeoPacakge (identify fails in the same
>>>> way), and
>>>> - ESRI PGDB (identify succeeds, which is frustrating!)
>>>> On Mon, Dec 10, 2018 at 9:12 AM James Klassen <klassen.js at gmail.com>
>>>> wrote:
>>>>> One thing to check is if the case of the properties. Different
>>>>> formats have different conventions about lower/mixed/uppercase for the
>>>>> properties/field names.
>>>>> If you look at the response to the GetFeatureInfo request is it
>>>>> showing data?
>>>>> Another thing if you aren't using the standard GeoMoose includes, you
>>>>> might be missing the metadata block to enable all the WMS/WFS request types.
>>>>> On Mon, Dec 10, 2018 at 8:49 AM TC Haddad <tchaddad at gmail.com> wrote:
>>>>>> Does anyone have a successful GM3 example of enabling Identify on
>>>>>> items in a SpatiaLite db?
>>>>>> I have a working example in GM2 that I am trying to transfer to GM3,
>>>>>> and everything I've tried is failing.
>>>>>> The layer draws just fine, and there are no significant error
>>>>>> messages, just no results.
>>>>>> Layer def and Mapbook snippet below, SpatiaLite db was created in
>>>>>> QGIS 2.18.
>>>>>> ---------------- fwd ---------------- >>
>>>>>> LAYER
>>>>>> NAME 'points'
>>>>>> CONNECTIONTYPE ogr
>>>>>> CONNECTION "\data\points.sqlite"
>>>>>> DATA "points"
>>>>>> STATUS ON
>>>>>> TYPE POINT
>>>>>> PROJECTION
>>>>>> 'init=epsg:3857'
>>>>>> END
>>>>>> METADATA
>>>>>> 'ows_title' 'points'
>>>>>> 'ows_include_items' 'all'
>>>>>> 'gml_include_items' 'all'
>>>>>> END
>>>>>> LABELCACHE ON
>>>>>> LABELITEM 'SERVICELOC'
>>>>>> TEMPLATE 'foo.html'
>>>>>> CLASS
>>>>>> NAME "Service Locations"
>>>>>> STYLE
>>>>>> SYMBOL "square"
>>>>>> SIZE 8.0
>>>>>> OUTLINECOLOR 0 0 0
>>>>>> COLOR 0 0 255
>>>>>> END
>>>>>> LABEL
>>>>>> TYPE TRUETYPE
>>>>>> FONT vera_sans
>>>>>> SIZE 8
>>>>>> ANTIALIAS TRUE
>>>>>> WRAP ' '
>>>>>> COLOR 0 0 255
>>>>>> OUTLINECOLOR 255 255 255
>>>>>> BUFFER 4
>>>>>> MINFEATURESIZE auto
>>>>>> PARTIALS FALSE
>>>>>> POSITION uc
>>>>>> END
>>>>>> END
>>>>>> TOLERANCE 30
>>>>>> END
>>>>>> <map-source name="points" type="mapserver">
>>>>>> <file>points.map</file>
>>>>>> <layer name="points" status="off">
>>>>>> <template name="identify"><![CDATA[
>>>>>> <div>
>>>>>> <div style="background-color:Gainsboro">
>>>>>> <b>Points</b>
>>>>>> </div>
>>>>>> <div class="item">
>>>>>> <label>Location Number:</label> {{
>>>>>> properties.LocNumber }}
>>>>>> </div>
>>>>>> <div class="item">
>>>>>> <label>Location Street:</label> {{
>>>>>> properties.LocStreet }}
>>>>>> </div>
>>>>>> </div>
>>>>>> ]]></template>
>>>>>> </layer>
>>>>>> <param name="FORMAT" value="image/png;bits=8"/>
>>>>>> </map-source>
>>>>>> _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181211/19dec5aa/attachment-0001.html>
More information about the Geomoose-users
