[Geomoose-users] remove the title field from the ui of the print service
Dan Little
theduckylittle at gmail.com
Thu Dec 13 05:31:10 PST 2018
Please reply to the whole list.
I did research it this morning. It requires adding a new option to the
printModal component. That requires a code change, new build, and release.
So the appropriate next step is to file an issue in GitHub or make a pull
request.
However, if the real bug is to fix Greek characters in the print then
please file that bug.
Please keep in mind that GeoMoose code updates are sometimes a bit slow
because much if the work is done on a volunteer basis.
On Thu, Dec 13, 2018, 7:25 AM <e.arapostathis at gmail.com wrote:
> Thank you, I will research it myself because I guess that it takes long
> for you to research it. It’s just that Greek characters are not displayed
> properly when I title is typed in that field. It should be a utf-8 encoding
> issue. Unless there is another tip you could provide I will try to find it
> out and remove it.
> This is my feedback in your fantastic application
> *From:* Dan Little <theduckylittle at gmail.com>
> *Sent:* Thursday, December 13, 2018 3:12 PM
> *To:* e.arapostathis at gmail.com
> *Cc:* GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> *Subject:* Re: [Geomoose-users] remove the title field from the ui of the
> print service
> There's no option for doing this in the current application. If you want
> then file a ticket on our GitHub repo and I'll research what it takes to
> add that feature. :-)
> Thanks!
> On Wed, Dec 12, 2018 at 5:04 PM Stathis G. Arapostathis <
> e.arapostathis at gmail.com> wrote:
> Dear Sirs/Madams
> I would like to ask how I can delete the "map title" field when I select
> the print service from the user interface of gm3.
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon>
> Virus-free. *www.avast.com*
> Geomoose-users mailing list
> *Geomoose-users at lists.osgeo.org*
> *https://lists.osgeo.org/mailman/listinfo/geomoose-users*
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181213/3d662b07/attachment.html>
More information about the Geomoose-users
