[Geomoose-users] remove the title field from the ui of the print service
e.arapostathis at gmail.com
Thu Dec 13 05:37:25 PST 2018
I’m very sorry that I didn’t reply to the whole list. I guess that there is no need to remove the map title field in the next gm release. I will file the utf-8 encoding issues but when I find time as I am a little bit occupied and I am not familiar with the issue or pull request process.
I will try to modify the printModal component myself.
Many congratulations for this fantastic application one more time
Stathis G.
Geographer, freelancer
Sent: Thursday, December 13, 2018 3:31 PM
To: e.arapostathis at gmail.com; GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] remove the title field from the ui of the print service
Please reply to the whole list.
I did research it this morning. It requires adding a new option to the printModal component. That requires a code change, new build, and release. So the appropriate next step is to file an issue in GitHub or make a pull request.
However, if the real bug is to fix Greek characters in the print then please file that bug.
Please keep in mind that GeoMoose code updates are sometimes a bit slow because much if the work is done on a volunteer basis.
On Thu, Dec 13, 2018, 7:25 AM <e.arapostathis at gmail.com <mailto:e.arapostathis at gmail.com> wrote:
Thank you, I will research it myself because I guess that it takes long for you to research it. It’s just that Greek characters are not displayed properly when I title is typed in that field. It should be a utf-8 encoding issue. Unless there is another tip you could provide I will try to find it out and remove it.
This is my feedback in your fantastic application
From: Dan Little <theduckylittle at gmail.com <mailto:theduckylittle at gmail.com> >
Sent: Thursday, December 13, 2018 3:12 PM
To: e.arapostathis at gmail.com <mailto:e.arapostathis at gmail.com>
Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org <mailto:geomoose-users at lists.osgeo.org> >
There's no option for doing this in the current application. If you want then file a ticket on our GitHub repo and I'll research what it takes to add that feature. :-)
Thanks!
On Wed, Dec 12, 2018 at 5:04 PM Stathis G. Arapostathis <e.arapostathis at gmail.com <mailto:e.arapostathis at gmail.com> > wrote:
Dear Sirs/Madams
I would like to ask how I can delete the "map title" field when I select the print service from the user interface of gm3.
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon> Virus-free. www.avast.com
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon> _______________________________________________
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181213/b1766a85/attachment-0001.html>
More information about the Geomoose-users
