[Geomoose-users] MinScale, MaxScale in GM 3.2
Renaud LAIRE
r.laire at parc-livradois-forez.org
Wed Dec 19 03:09:17 PST 2018
Hi, I have large datafile and i try de limit the display on scale based rule with GM3.2 (https://carhab.parc-livradois-forez.org)
To do i use scale limit in <map-source> , But it seems doesn't work, , i try to put in catalog, like GM2.9 with the same result
<map-source name="carhab" type="mapserver" up="true" down="true" title="Cartographie des Habitats" >
<file>./maps/carhab.map</file>
<layer name="carhab_poly" status="off" query-as="carhab-wfs/carhab_search" minscale="6000" maxscale="20000" >
<template name="identify" src="./templates/carhab/identify_carhab.html"/>
</layer>
<layer name="carhab_poly_series" status="off">
</layer>
</map-source>
<layer title="Catégories Physionomiques des végétations du Parc" src="carhab/carhab_poly" maxscale="75000" status="on" fade="true" unfade="true"/>
Renaud LAIRE
PNR Livradois Forez
Maison du Parc
63880 ST Gervais sous Meymont
04 73 95 57 57
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181219/85738636/attachment-0001.html>
More information about the Geomoose-users
