[Geomoose-users] Template / Results Issues
Dan Little
theduckylittle at gmail.com
Wed Feb 7 10:36:38 PST 2018
I was more curious about the international characters... but that said, yes
having "properties" is important because you can also access "geometry."
The template system works by taking GeoJSON formatted-features and running
them, on a loop, through the template.
On Wed, Feb 7, 2018 at 8:57 AM, Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Correct, I consistently got Tanya's error (different browsers) with GM 3.1
> if I only specified "{{ FIELDNAME }}" in the identify section; solution was
> to specify "{{ properties.FIELDNAME }}"
> -jeff
> On 2018-02-07 10:47 AM, Dan Little wrote:
>> Yes, please post up the Mapbook snippet of the affected code and, if
>> possible, a snippet of the data returned from the WFS request.
>> Jeff, were you consistently getting that error with the international
>> characters dataset? If so, I should really test that.
>> On Wed, Feb 7, 2018 at 8:45 AM, Jeff McKenna <
>> jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>> wrote:
>> Hi Tanya,
>> I've tested with the included "Test International Characters" layer
>> that is included in the packaged mapbook.xml by default, using MS4W
>> version 3.2.3
>> I was able to get your exact same error through an identify on that
>> layer.
>> I fixed this by making sure to specify "{{ properties.FIELDNAME }}"
>> in my mapbook.xml (at first I had just "{{ FIELDNAME }}"). Here is
>> the working section:
>> https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8cd20b3
>> <https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8cd20b3>
>> Maybe your issue is similar.
>> -jeff
>> -- Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/ <http://www.gatewaygeomatics.com/>
>> On 2018-02-07 2:27 AM, TC Haddad wrote:
>> hi all,
>> I've just been testing 3.1 with some local data, and have a
>> weird issue with displaying the results from Identify, Select,
>> and Search.
>> I'm getting correct number of records and fields returning for
>> each item clicked, selected, or found via a search, but result
>> contents all display as "???".
>> example: http://bit.ly/2FS8ySS
>> I feel like I'm missing something really basic - any ideas why
>> my templates aren't correctly populating?
> Jeff McKenna
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180207/60ea1d94/attachment-0001.html>
More information about the Geomoose-users
