[Geomoose-users] Template / Results Issues
TC Haddad
tchaddad at gmail.com
Wed Feb 7 10:55:47 PST 2018
Thanks for the lead - I left this particular project at home today, so I
will test Jeff's suggestion tonight and report back with some snippets...
Tanya
On Wed, Feb 7, 2018 at 10:36 AM, Dan Little <theduckylittle at gmail.com>
wrote:
> I was more curious about the international characters... but that said,
> yes having "properties" is important because you can also access
> "geometry." The template system works by taking GeoJSON formatted-features
> and running them, on a loop, through the template.
> On Wed, Feb 7, 2018 at 8:57 AM, Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> Correct, I consistently got Tanya's error (different browsers) with GM
>> 3.1 if I only specified "{{ FIELDNAME }}" in the identify section; solution
>> was to specify "{{ properties.FIELDNAME }}"
>> -jeff
>> On 2018-02-07 10:47 AM, Dan Little wrote:
>>> Yes, please post up the Mapbook snippet of the affected code and, if
>>> possible, a snippet of the data returned from the WFS request.
>>> Jeff, were you consistently getting that error with the international
>>> characters dataset? If so, I should really test that.
>>> On Wed, Feb 7, 2018 at 8:45 AM, Jeff McKenna <
>>> jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>>> wrote:
>>> Hi Tanya,
>>> I've tested with the included "Test International Characters" layer
>>> that is included in the packaged mapbook.xml by default, using MS4W
>>> version 3.2.3
>>> I was able to get your exact same error through an identify on that
>>> layer.
>>> I fixed this by making sure to specify "{{ properties.FIELDNAME }}"
>>> in my mapbook.xml (at first I had just "{{ FIELDNAME }}"). Here is
>>> the working section:
>>> https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8cd20b3
>>> <https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8cd20b3>
>>> Maybe your issue is similar.
>>> -jeff
>>> -- Jeff McKenna
>>> MapServer Consulting and Training Services
>>> http://www.gatewaygeomatics.com/ <http://www.gatewaygeomatics.com/>
>>> On 2018-02-07 2:27 AM, TC Haddad wrote:
>>> hi all,
>>> I've just been testing 3.1 with some local data, and have a
>>> weird issue with displaying the results from Identify, Select,
>>> and Search.
>>> I'm getting correct number of records and fields returning for
>>> each item clicked, selected, or found via a search, but result
>>> contents all display as "???".
>>> example: http://bit.ly/2FS8ySS
>>> I feel like I'm missing something really basic - any ideas why
>>> my templates aren't correctly populating?
>> Jeff McKenna
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180207/75753c93/attachment.html>
More information about the Geomoose-users
