[Geomoose-users] Template / Results Issues
    TC Haddad
    tchaddad at gmail.com
    Thu Feb  8 07:06:40 PST 2018
Solved - turned out it was something else entirely!
Further digging showed that the GML returning actually only contained
geometry, and no attributes, so that explained correct number of results,
correct zooming, etc, with no template population.
That led me to the mapfile, where I realized I put  'ows_include_items'
'all'  'gml_include_items' 'all' in the METADATA at the MAP level (where it
does nothing) rather at the LAYER level.
So, basic Mapserver mistake on my part, ah well - thanks for the help, got
me looking in the right places...
On Wed, Feb 7, 2018 at 10:55 AM, TC Haddad <tchaddad at gmail.com> wrote:
> Thanks for the lead - I left this particular project at home today, so I
> will test Jeff's suggestion tonight and report back with some snippets...
> Tanya
> On Wed, Feb 7, 2018 at 10:36 AM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> I was more curious about the international characters... but that said,
>> yes having "properties" is important because you can also access
>> "geometry." The template system works by taking GeoJSON formatted-features
>> and running them, on a loop, through the template.
>> On Wed, Feb 7, 2018 at 8:57 AM, Jeff McKenna <
>> jmckenna at gatewaygeomatics.com> wrote:
>>> Correct, I consistently got Tanya's error (different browsers) with GM
>>> 3.1 if I only specified "{{ FIELDNAME }}" in the identify section; solution
>>> was to specify "{{ properties.FIELDNAME }}"
>>> -jeff
>>> On 2018-02-07 10:47 AM, Dan Little wrote:
>>>> Yes, please post up the Mapbook snippet of the affected code and, if
>>>> possible, a snippet of the data returned from the WFS request.
>>>> Jeff, were you consistently getting that error with the international
>>>> characters dataset? If so, I should really test that.
>>>> On Wed, Feb 7, 2018 at 8:45 AM, Jeff McKenna <
>>>> jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>>>> wrote:
>>>>     Hi Tanya,
>>>>     I've tested with the included "Test International Characters" layer
>>>>     that is included in the packaged mapbook.xml by default, using MS4W
>>>>     version 3.2.3
>>>>     I was able to get your exact same error through an identify on that
>>>>     layer.
>>>>     I fixed this by making sure to specify "{{ properties.FIELDNAME }}"
>>>>     in my mapbook.xml (at first I had just "{{ FIELDNAME }}").  Here is
>>>>     the working section:
>>>>     https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8cd20b3
>>>>     <https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8cd20b3
>>>>     Maybe your issue is similar.
>>>>     -jeff
>>>>     --     Jeff McKenna
>>>>     MapServer Consulting and Training Services
>>>>     http://www.gatewaygeomatics.com/ <http://www.gatewaygeomatics.com/>
>>>>     On 2018-02-07 2:27 AM, TC Haddad wrote:
>>>>         hi all,
>>>>         I've just been testing 3.1 with some local data, and have a
>>>>         weird issue with displaying the results from Identify, Select,
>>>>         and Search.
>>>>         I'm getting correct number of records and fields returning for
>>>>         each item clicked, selected, or found via a search, but result
>>>>         contents all display as "???".
>>>>         example: http://bit.ly/2FS8ySS
>>>>         I feel like I'm missing something really basic - any ideas why
>>>>         my templates aren't correctly populating?
>>> Jeff McKenna
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180208/0c55b9dd/attachment.html>
More information about the Geomoose-users
