[Geomoose-users] automatically redirecting geomoose http to https using apache
James Klassen
klassen.js at gmail.com
Fri Mar 30 06:05:27 PDT 2018
I'm not sure about this. Redirect is supposed to work with everything
under the circumstances configured path so the /app1/ lines are redundant
to the / line. Also, IIRC you need to prevent a redirect loop where the
https site continually redirects to itself.
You also need both an http site (on port 80, without sslengine) to at a
minimum host the redirect and an https site (on port 443, with sslengine
on). Since you say both http and https are working now, but no automatic
redirect, I don't understand how that works (where one apache instance is
handling both) without already having the two virtual hosts already defined
somewhere.
On Thu, Mar 29, 2018, 16:40 TC Haddad <tchaddad at gmail.com> wrote:
> Before going to virtual hosts,
> Since you already have https working on the root, and only have one
> domain, I would try simply augmenting the redirects you have put in place
> to include permanent redirects for the relevant apps.
> You already have:
> Redirect permanent / https://www.mysite.com/
> <https://www.mysite.com/app1/>
> you could add:
> Redirect permanent /app1/ https://www.mysite.com/app1/
> Redirect permanent /app2/ https://www.mysite.com/app2/
> Redirect permanent /app3/ https://www.mysite.com/app3/
> On Thu, Mar 29, 2018 at 1:20 PM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> I would suggest first re-writing your Apache configuration to use a
>> VirtualHost on port 80 that serves your current data. Then do the
>> transition.
>> On Thu, Mar 29, 2018 at 3:19 PM, Mark Volz <MarkVolz at co.lyon.mn.us>
>> wrote:
>>> Dan,
>>> Thank you for your reply. I noticed that wiki, and a few others seemed
>>> to favor using virtual host to get the job done. I noticed <VirtualHost
>>> _default_:443> is part of httpd-ssl.conf. However, <VirtualHost *:80> is
>>> not found in any of the configuration files. Do we just add virtual host
>>> right in httpd.conf?
>>> Thanks
>>> Sincerely,
>>> *Mark Volz, GISP*
>>> *From:* Dan Little [mailto:theduckylittle at gmail.com]
>>> *Sent:* Thursday, March 29, 2018 3:05 PM
>>> *To:* Mark Volz <MarkVolz at co.lyon.mn.us>
>>> *Cc:* geomoose-users at lists.osgeo.org
>>> *Subject:* Re: [Geomoose-users] automatically redirecting geomoose http
>>> Not really a GeoMoose question but...
>>> https://wiki.apache.org/httpd/RedirectSSL
>>> Bashing "apache forward http to https" will also lead you to a number of
>>> useful guides on the subject. :-)
>>> On Thu, Mar 29, 2018 at 3:02 PM, Mark Volz <MarkVolz at co.lyon.mn.us>
>>> wrote:
>>> Hello,
>>> Similar to the demo.geomoose.org site, I am trying to find a way to
>>> automatically redirect my geomoose web traffic from http:// to https://
>>> using Apache. It is my understanding that Google will start shaming non
>>> https:// websites. If anyone has any notes as far as how to set it up
>>> please let me know. Thus far I can get https:// working if a user
>>> manually types in https:// however the automatic redirection is failing.
>>> Thank You!
>>> Sincerely,
>>> *Mark Volz, GISP*
>>> *Lyon County GIS Coordinator*
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180330/ac976cbc/attachment-0001.html>
More information about the Geomoose-users
