[Geomoose-users] GM3 Coordinate Display precision
James Klassen
klassen.js at gmail.com
Sun Jan 13 07:39:23 PST 2019
What version are you using?
precision should be an integer. There was a bug at one point where it
didn't differentiate between 0 and not set, I wonder if you hit that? In
that case higher integers worked, just not 0.
Also you have an extra comma after the precision line which might trip up
some browsers.
On Sat, Jan 12, 2019, 20:51 Kevin Grootendorst <kgrootendorst at gmail.com
wrote:
> Thanks Jim. Had to make a slight change to make it work:
> var point_projections = [
> label: 'UTM 17N',
> ref: 'EPSG:26917',
> precision: '0',
> On Sat, 12 Jan 2019 at 21:39, James Klassen <klassen.js at gmail.com> wrote:
>> Already covered. Add precision to the point_projections array in app.js.
>> And probably also worth a issue to add this to the docs if it isn't in
>> there.
>> ex:
>> label: 'X,Y',
>> ref: 'EPSG:200068',
>> precision: 0
>> On Sat, Jan 12, 2019, 18:38 Kevin Grootendorst <kgrootendorst at gmail.com
>> wrote:
>>> All,
>>> In the footer of my app, I'm displaying coordinates in UTM 17, however,
>>> it defaults to 10 decimal places. Can this be changed to 1 or 0 decimals?
>>> From searching the list archives, I see that pre-v3, there was a
>>> coordinate_display.js or main.js that could be modified to change precision.
>>> I'm guessing this could be done in the app.js file in GM3, but not sure
>>> where/how to implement.
>>> Is it in the app.addProjection?
>>> app.addProjection({
>>> ref: 'EPSG:26917',
>>> def: '+proj=utm +zone=17 +ellps=GRS80 +datum=NAD83 +units=m
>>> +no_defs'
>>> Cheers,
>>> Kevin
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190113/0d2fd27f/attachment.html>
More information about the Geomoose-users
