[Geomoose-users] GM3 Coordinate Display precision
Kevin Grootendorst
kgrootendorst at gmail.com
Sun Jan 13 11:19:16 PST 2019
I'm using 3.2.1
If I set to an integer of 0 (removed single quotes), precision fails on
Firebox and Edge browsers.
Only when I use '0', will it work for Firefox and Edge. Chrome seemed to
work with either(?).
Kevin
On Sun, 13 Jan 2019 at 10:39, James Klassen <klassen.js at gmail.com> wrote:
> What version are you using?
> precision should be an integer. There was a bug at one point where it
> didn't differentiate between 0 and not set, I wonder if you hit that? In
> that case higher integers worked, just not 0.
> Also you have an extra comma after the precision line which might trip up
> some browsers.
> On Sat, Jan 12, 2019, 20:51 Kevin Grootendorst <kgrootendorst at gmail.com
> wrote:
>> Thanks Jim. Had to make a slight change to make it work:
>> var point_projections = [
>> label: 'UTM 17N',
>> ref: 'EPSG:26917',
>> precision: '0',
>> On Sat, 12 Jan 2019 at 21:39, James Klassen <klassen.js at gmail.com> wrote:
>>> Already covered. Add precision to the point_projections array in app.js.
>>> And probably also worth a issue to add this to the docs if it isn't in
>>> there.
>>> ex:
>>> label: 'X,Y',
>>> ref: 'EPSG:200068',
>>> precision: 0
>>> On Sat, Jan 12, 2019, 18:38 Kevin Grootendorst <kgrootendorst at gmail.com
>>> wrote:
>>>> All,
>>>> In the footer of my app, I'm displaying coordinates in UTM 17, however,
>>>> it defaults to 10 decimal places. Can this be changed to 1 or 0 decimals?
>>>> From searching the list archives, I see that pre-v3, there was a
>>>> coordinate_display.js or main.js that could be modified to change precision.
>>>> I'm guessing this could be done in the app.js file in GM3, but not sure
>>>> where/how to implement.
>>>> Is it in the app.addProjection?
>>>> app.addProjection({
>>>> ref: 'EPSG:26917',
>>>> def: '+proj=utm +zone=17 +ellps=GRS80 +datum=NAD83 +units=m
>>>> +no_defs'
>>>> Cheers,
>>>> Kevin
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190113/275cbeca/attachment.html>
More information about the Geomoose-users
