[Geomoose-users] mapserver - mapserver-wfs and search service
e.arapostathis e.arapostathis at gmail.com
Wed Jan 16 13:26:46 PST 2019
Tanya I love you!
Thank you very much. Thank you so much. That was the problem. The search service works perfectly!!!!
Stathis
Στάλθηκε από το smartphone Samsung Galaxy.
-------- Αρχικό μήνυμα --------Από: TC Haddad <tchaddad at gmail.com> Ημερομηνία: 16/1/19  23:05  (GMT+02:00) Προς: Jim Klassen <klassen.js at gmail.com> Κοιν.: geomoose-users at lists.osgeo.org Θέμα: Re: [Geomoose-users] mapserver - mapserver-wfs and search service
Can you report the epsg code for your layer?
And then, can you check the order of the epsg codes listed in your
 INCLUDE '../../common_metadata.map'file?
I've found that the projection of the layer being searched needs to be listed first in the list of projections for
'ows_srs' and
'wfs_srs, otherwise the search will return no results.
Not sure if that is a bug, but I've had it come up with users a couple of times, and have been meaning to report it so that people are at least aware of it. It's particularly hard for users to figure out because the key lines are in the INCLUDE file.
maybe that helps you solve the problem?
Tanya
On Mon, Jan 14, 2019 at 9:56 AM Jim Klassen <klassen.js at gmail.com> wrote:
    I think that means that MapServer isn't returning any results.
      There are many potential causes for that.  It could be the query
      is running properly but not returning any features because nothing
      matched, it could be there is a problem in the mapfile or mapbook,
      maybe an encoding problem, ...
    Can you see what GeoMoose is sending to mapserver and how
      mapserver is responding using the browser developer tools?
    On 1/12/19 5:08 PM, Stathis G.
      Arapostathis wrote:
          Hello,
            I followed the example of the parcels dataset of the
              gm3 demo and I created two map-sources in mapbook for the
              same dataset.
            The first one uses type = mapserver while the second
              one uses type = mapserver-wfs.
            I did this because the search service does not work
              with the mapserver type.
            I can see both of my layers in my geomoose app (the
              names of the layers are cemeteries/cemeteries and
              vector-cemeteries/cemeteries).
            But:
            When i use search with the the
              vector-cemeteries/cemeteries layer (type=mapserver-wfs)
              the layer is recognized (I see layer:1 in the results) but
              the features are not (I see features:0 in the results). As
              a result search is not working properly.
            I use the same .map file for both of them layers of
              mapbook.
            Below you can find the search template and the addition
              in app.js
            My search template is pretty simple:
              <![CDATA[
                              <div class="search-result">
                                  <div class="search-label">
                                      {{ properties.name
                                  </div>
                                  <div class="search-action">
                                      <div style="padding:
                2px">
                                          <a
                onClick="app.zoomToExtent([{{ properties.boundedBy |
                join }}])" class="zoomto-link">
                                              <i class="fa
                fa-search"></i>
                                              {{ properties.id
                                          </a>
                                      </div>
                                  </div>
                                  <div
                class="search-address">
                                      {{ properties.name
                }}<br/>
                                      {{ properties.city
                }}<br/>
                                  </div>
                              </div>
            The javascript code of the app.js is:
              app.registerService('search-cemeteries',
                SearchService, {
                       searchLayers:
                ['vector-cemeteries/cemeteries'],
              		fields: [
                          {type: 'select', label: 'City', name:
                "id",
                           options: [
                              { label: "Ακρωτήριο Πούντα", value:
                "17" },
              				{ label:
                "Αλεξανδρούπολη", value: "6" },
                              { label: "Θεσσαλονίκη (Ζέιτενλινκ)",
                value: "2" },
              			    { label:
                "Καλαμαριά (κοιμητήριο)", value: "18" },
              				{ label:
                "Καλαμαριά (επιτύμβιες στήλες)", value: "3" },
              				{ label:
                "Καλοσκοπή", value: "10" },
                              { label: "Καρούτες", value: "12" },
              				{ label:
                "Κάτω Κορυφή", value: "11" },
              				{ label:
                "Μεσόβουνο  (Κοζάνη)", value: "9" },
                              { label: "Μούδρος", value: "7" },
              				{ label:
                "Μπράλος", value: "8" },
              				{ label:
                "Παλαιό Φάληρο", value: "13" },
                              { label: "Πειραιάς", value: "1" },
              				{ label:
                "Πεντάλοφος (Κοζάνη)", value: "16" },
              				{ label:
                "Ρέθυμνο", value: "4" },
                              { label: "Στυλίδα", value: "14" },
              				{ label:
                "Σφακτηρία (Μεσσηνία)", value: "15" },
                              { label: "Χανιά", value: "5" }
              Virus-free.
                www.avast.com
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190116/294ca787/attachment-0001.html>
More information about the Geomoose-users mailing list
