[Geomoose-users] mapserver - mapserver-wfs and search service
TC Haddad
tchaddad at gmail.com
Wed Jan 16 13:51:09 PST 2019
Great! I will definitely put this in Github as at least a documentation
issue.
Tanya
On Wed, Jan 16, 2019 at 1:26 PM e.arapostathis <e.arapostathis at gmail.com>
wrote:
> Tanya I love you!
> Thank you very much. Thank you so much. That was the problem. The search
> service works perfectly!!!!
> Stathis
> Στάλθηκε από το smartphone Samsung Galaxy.
> -------- Αρχικό μήνυμα --------
> Από: TC Haddad <tchaddad at gmail.com>
> Ημερομηνία: 16/1/19 23:05 (GMT+02:00)
> Προς: Jim Klassen <klassen.js at gmail.com>
> Κοιν.: geomoose-users at lists.osgeo.org
> Θέμα: Re: [Geomoose-users] mapserver - mapserver-wfs and search service
> Can you report the epsg code for your layer?
> And then, can you check the order of the epsg codes listed in your INCLUDE
> '../../common_metadata.map'file?
> I've found that the projection of the layer being searched needs to be
> listed* first *in the list of projections for 'ows_srs' and 'wfs_srs,
> otherwise the search will return no results.
> Not sure if that is a bug, but I've had it come up with users a couple of
> times, and have been meaning to report it so that people are at least aware
> of it. It's particularly hard for users to figure out because the key lines
> are in the INCLUDE file.
> maybe that helps you solve the problem?
> Tanya
> On Mon, Jan 14, 2019 at 9:56 AM Jim Klassen <klassen.js at gmail.com> wrote:
>> I think that means that MapServer isn't returning any results. There are
>> many potential causes for that. It could be the query is running properly
>> but not returning any features because nothing matched, it could be there
>> is a problem in the mapfile or mapbook, maybe an encoding problem, ...
>> Can you see what GeoMoose is sending to mapserver and how mapserver is
>> responding using the browser developer tools?
>> On 1/12/19 5:08 PM, Stathis G. Arapostathis wrote:
>> Hello,
>> I followed the example of the parcels dataset of the gm3 demo and I
>> created two map-sources in mapbook for the same dataset.
>> The first one uses type = mapserver while the second one uses type =
>> mapserver-wfs.
>> I did this because the search service does not work with the mapserver
>> type.
>> I can see both of my layers in my geomoose app (the names of the layers
>> are cemeteries/cemeteries and vector-cemeteries/cemeteries).
>> But:
>> When i use search with the the vector-cemeteries/cemeteries layer
>> (type=mapserver-wfs) the layer is recognized (I see layer:1 in the results)
>> but the features are not (I see features:0 in the results). As a result
>> search is not working properly.
>> I use the same .map file for both of them layers of mapbook.
>> Below you can find the search template and the addition in app.js
>> My search template is pretty simple:
>> <![CDATA[
>> <div class="search-result">
>> <div class="search-label">
>> {{ properties.name }}
>> </div>
>> <div class="search-action">
>> <div style="padding: 2px">
>> <a onClick="app.zoomToExtent([{{
>> properties.boundedBy | join }}])" class="zoomto-link">
>> <i class="fa fa-search"></i>
>> {{ properties.id }}
>> </a>
>> </div>
>> </div>
>> <div class="search-address">
>> {{ properties.name }}<br/>
>> {{ properties.city }}<br/>
>> </div>
>> </div>
>> The javascript code of the app.js is:
>> app.registerService('search-cemeteries', SearchService, {
>> searchLayers: ['vector-cemeteries/cemeteries'],
>> fields: [
>> {type: 'select', label: 'City', name: "id",
>> options: [
>> { label: "Ακρωτήριο Πούντα", value: "17" },
>> { label: "Αλεξανδρούπολη", value: "6" },
>> { label: "Θεσσαλονίκη (Ζέιτενλινκ)", value: "2" },
>> { label: "Καλαμαριά (κοιμητήριο)", value: "18" },
>> { label: "Καλαμαριά (επιτύμβιες στήλες)", value: "3" },
>> { label: "Καλοσκοπή", value: "10" },
>> { label: "Καρούτες", value: "12" },
>> { label: "Κάτω Κορυφή", value: "11" },
>> { label: "Μεσόβουνο (Κοζάνη)", value: "9" },
>> { label: "Μούδρος", value: "7" },
>> { label: "Μπράλος", value: "8" },
>> { label: "Παλαιό Φάληρο", value: "13" },
>> { label: "Πειραιάς", value: "1" },
>> { label: "Πεντάλοφος (Κοζάνη)", value: "16" },
>> { label: "Ρέθυμνο", value: "4" },
>> { label: "Στυλίδα", value: "14" },
>> { label: "Σφακτηρία (Μεσσηνία)", value: "15" },
>> { label: "Χανιά", value: "5" }
>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=icon> Virus-free.
>> www.avast.com
>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link>
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190116/3dc5bea3/attachment.html>
More information about the Geomoose-users
