[Geomoose-users] Geomoose 3, URL call to start a service with parameters
James Klassen klassen.js at gmail.com
Tue Aug 18 10:30:30 PDT 2020
I'm +1 for using lat/lon over 3857 by default in the hash tracker.  This is
a lot clearer for users and really only causes problems near the poles, but
otherwise doesn't prevent using other map projections.  Since 3857 has the
same problems near the poles, this is only an issue if we allow non-3857 in
the future and we don't keep loc= as a fallback.
Hash track could always detect loc and use that for the session if it is
there but otherwise use xyz (or let the default of using xyz vs. loc be
settable in app.js).  I'm not sure what happens if the user provides both.
xyz seems like an odd name for lat/lon... maybe pos, position, l, ll?
I'm rather ambivalent about the web merc Z levels.  They don't have an
intuitive meaning for me, but it is in common use, I guess.
I'm not sure this get to the "zoom to feature on startup" or "zoom to
bounding box" comment that opened this thread, but I expect that should be
doable with some code in app.js.
On Mon, Aug 17, 2020, 17:13 Dan Little <theduckylittle at gmail.com> wrote:
> I know I'm playing catch up from the last 60 days, but if someone tickets
> this I will do my best to document the `loc=` parameter. For some context:
> - The earlier releases of OL3/4 made "resolution" more prominent over
> "zoom" level.
> - I was originally sticking with it because we hoped to support more than
> webmercator.
> I'm willing to hear out deprecating `loc=` in favor of something more like
> `xyz=` since we could use `xyz` with lat long and the "normal" webmerc zoom
> levels.
> On Wed, Jun 10, 2020 at 10:57 AM Christopher Hughes <
> chughes at co.lincoln.or.us> wrote:
>> Brent,
>> That was exactly what I was referring to, thanks! It definitely helps
>> knowing what that zoom/resolution parameter is
>> referring to. Now to figure out how to programmatically reproduce it.
>> On Wed, Jun 10, 2020 at 8:39 AM TC Haddad <tchaddad at gmail.com> wrote:
>>> +1 for some clarity or examples on how to do this.
>>> It seems related to bookmarking, which is discussed in this old issue:
>>> https://github.com/geomoose/gm3/issues/66
>>> On Wed, Jun 10, 2020 at 8:28 AM Brent Fraser <bfraser at geoanalytic.com>
>>> wrote:
>>>> Chris,
>>>>  The "loc" hash parameter in the url has a resolution value (not quite
>>>> the
>>>> same zoom but close):
>>>>  loc=50;-10321714;5584217
>>>>  would be:  zoom to 50m./pixel, center map at X=-10321714 Y=5584217
>>>>  Or did you mean something else?
>>>>  Brent
>>>>  -------- Original Message --------
>>>> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>>>> > Sent: June 10, 2020 9:18 AM
>>>> > To: "Eli Adam" <eadam at co.lincoln.or.us>
>>>> > Cc: "geomoose-users-osgeo" <geomoose-users at lists.osgeo.org>
>>>> > Subject: Re: [Geomoose-users] Geomoose 3,URL call to start a service
>>>> with
>>>> parameters
>>>> > Does anyone know how the zoom parameter is determined in the url?
>>>> > We have a similar situation where we have a dataset of links to each
>>>> parcel
>>>> > that specify a bounding box
>>>> > (rather than GeoMoose 3's zoom and point). Converting these to web
>>>> mercator
>>>> > isn't much of an issue
>>>> > (or finding parcel centroids in web mercator), but I haven't figured
>>>> out
>>>> > how to programmatically create
>>>> > URL's that include a zoom and a point parameter.
>>>> > Chris
>>>> > On Tue, Jun 9, 2020 at 7:41 AM Eli Adam <eadam at co.lincoln.or.us>
>>>> wrote:
>>>> > > Hi Michael,
>>>> > > On Tue, Jun 9, 2020 at 5:13 AM Reynolds, Michael J. (MNIT)
>>>> > > <mike.reynolds at state.mn.us> wrote:
>>>> > > > Is there a way to call a service or action by using a url
>>>> parameter?
>>>> If
>>>> > > not, in the app.js could I inspect the URL parameters and if I see a
>>>> > > particular parameter name (for example "service"), initiate a
>>>> service
>>>> after
>>>> > > the app loads?
>>>> > > You can run services at startup,
>>>> > > https://geomoose.github.io/gm3/howto/start-a-service.html
>>>> > > https://github.com/geomoose/gm3/issues/455
>>>> > > Best regards, Eli
>>>> > > > We've got user cases where users have Latitutde Longitude (WGS84)
>>>> for
>>>> > > locations which they would like to pass to a Geomoose URL as
>>>> parameters
>>>> to
>>>> > > go to that location directly. Users have noticed the coordinate
>>>> values
>>>> > > inherent in a Geomoose url but converting from WGS84 to web
>>>> mercator is
>>>> an
>>>> > > extra step.
>>>> > > > Any tips appreciated.
>>>> > > > Michael Reynolds
>>>> > > > Application Support | Application Portfolio Management (APM)
>>>> > > > Minnesota IT Services | Partnering with MnDOT
>>>> > > > 359 John Ireland Blvd.
>>>> > > > St. Paul, MN 55155
>>>> > > > O: 651-366-4918
>>>> > > > Information Technology for Minnesota Government | mn.gov/mnit
>>>> > > > _______________________________________________
>>>> > > > Geomoose-users mailing list
>>>> > > > Geomoose-users at lists.osgeo.org
>>>> > > > https://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> > Chris Hughes
>>>> > GIS Analyst
>>>> > Lincoln County Surveyor Department
>>>> > 880 NE 7th St. l Newport, OR 97365
>>>> > Tel: (541) 574 1283
>>>> > _______________________________________________ Geomoose-users
>>>> mailing
>>>> list Geomoose-users at lists.osgeo.org
>> Chris Hughes
>> GIS Analyst
>> Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200818/cd3bec99/attachment-0001.html>
More information about the Geomoose-users mailing list
