[Geomoose-users] Geomoose 3, URL call to start a service with parameters
Dan Little
theduckylittle at gmail.com
Mon Aug 17 15:13:39 PDT 2020
I know I'm playing catch up from the last 60 days, but if someone tickets
this I will do my best to document the `loc=` parameter. For some context:
- The earlier releases of OL3/4 made "resolution" more prominent over
"zoom" level.
- I was originally sticking with it because we hoped to support more than
webmercator.
I'm willing to hear out deprecating `loc=` in favor of something more like
`xyz=` since we could use `xyz` with lat long and the "normal" webmerc zoom
levels.
On Wed, Jun 10, 2020 at 10:57 AM Christopher Hughes <
chughes at co.lincoln.or.us> wrote:
> Brent,
> That was exactly what I was referring to, thanks! It definitely helps
> knowing what that zoom/resolution parameter is
> referring to. Now to figure out how to programmatically reproduce it.
> On Wed, Jun 10, 2020 at 8:39 AM TC Haddad <tchaddad at gmail.com> wrote:
>> +1 for some clarity or examples on how to do this.
>> It seems related to bookmarking, which is discussed in this old issue:
>> https://github.com/geomoose/gm3/issues/66
>> On Wed, Jun 10, 2020 at 8:28 AM Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> Chris,
>>> The "loc" hash parameter in the url has a resolution value (not quite
>>> the
>>> same zoom but close):
>>> loc=50;-10321714;5584217
>>> would be: zoom to 50m./pixel, center map at X=-10321714 Y=5584217
>>> Or did you mean something else?
>>> Brent
>>> -------- Original Message --------
>>> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>>> > Sent: June 10, 2020 9:18 AM
>>> > To: "Eli Adam" <eadam at co.lincoln.or.us>
>>> > Cc: "geomoose-users-osgeo" <geomoose-users at lists.osgeo.org>
>>> > Subject: Re: [Geomoose-users] Geomoose 3,URL call to start a service
>>> with
>>> parameters
>>> > Does anyone know how the zoom parameter is determined in the url?
>>> > We have a similar situation where we have a dataset of links to each
>>> parcel
>>> > that specify a bounding box
>>> > (rather than GeoMoose 3's zoom and point). Converting these to web
>>> mercator
>>> > isn't much of an issue
>>> > (or finding parcel centroids in web mercator), but I haven't figured
>>> out
>>> > how to programmatically create
>>> > URL's that include a zoom and a point parameter.
>>> > Chris
>>> > On Tue, Jun 9, 2020 at 7:41 AM Eli Adam <eadam at co.lincoln.or.us>
>>> wrote:
>>> > > Hi Michael,
>>> > > On Tue, Jun 9, 2020 at 5:13 AM Reynolds, Michael J. (MNIT)
>>> > > <mike.reynolds at state.mn.us> wrote:
>>> > > > Is there a way to call a service or action by using a url
>>> parameter?
>>> If
>>> > > not, in the app.js could I inspect the URL parameters and if I see a
>>> > > particular parameter name (for example "service"), initiate a
>>> service
>>> after
>>> > > the app loads?
>>> > > You can run services at startup,
>>> > > https://geomoose.github.io/gm3/howto/start-a-service.html
>>> > > https://github.com/geomoose/gm3/issues/455
>>> > > Best regards, Eli
>>> > > > We've got user cases where users have Latitutde Longitude (WGS84)
>>> for
>>> > > locations which they would like to pass to a Geomoose URL as
>>> parameters
>>> to
>>> > > go to that location directly. Users have noticed the coordinate
>>> values
>>> > > inherent in a Geomoose url but converting from WGS84 to web mercator
>>> is
>>> an
>>> > > extra step.
>>> > > > Any tips appreciated.
>>> > > > Michael Reynolds
>>> > > > Application Support | Application Portfolio Management (APM)
>>> > > > Minnesota IT Services | Partnering with MnDOT
>>> > > > 359 John Ireland Blvd.
>>> > > > St. Paul, MN 55155
>>> > > > O: 651-366-4918
>>> > > > Information Technology for Minnesota Government | mn.gov/mnit
>>> > > > _______________________________________________
>>> > > > Geomoose-users mailing list
>>> > > > Geomoose-users at lists.osgeo.org
>>> > > > https://lists.osgeo.org/mailman/listinfo/geomoose-users
>>> > Chris Hughes
>>> > GIS Analyst
>>> > Lincoln County Surveyor Department
>>> > 880 NE 7th St. l Newport, OR 97365
>>> > Tel: (541) 574 1283
>>> > _______________________________________________ Geomoose-users mailing
>>> list Geomoose-users at lists.osgeo.org
> Chris Hughes
> GIS Analyst
> Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200817/ae476ac1/attachment.html>
More information about the Geomoose-users
