[Geomoose-users] GeoMoose 3 - Speed
    Christopher Hughes
    chughes at co.lincoln.or.us
    Mon Feb  3 13:41:36 PST 2020
I reprojected our survey data to 3857 to test it out and it loads similarly
to our survey data in our current geomoose 2 build on linux (much much
faster).
Chris
On Mon, Feb 3, 2020 at 1:33 PM TC Haddad <tchaddad at gmail.com> wrote:
> For the contours data, and any data that is not dynamic, I’d strongly
> recommend turning on MS4W’s  MapCache, so the cache can be in 3857 and your
> original data can stay as is. You can set it up so that you do not have to
> precache, and instead cache on the fly. Works very well.
> For the survey data, which I assume changes more frequently, I would try
> setting up a PostGIS view in 3857, so that the reprojection is not done by
> Mapserver or GeoMoose. Not sure how much it will help but it should improve
> the situation to some degree.
> On Mon, Feb 3, 2020 at 4:00 PM Christopher Hughes <
> chughes at co.lincoln.or.us> wrote:
>> It looks like it may be the reprojection. If I set all the parameters and
>> extents to our local projection in the mapfile and in the
>> geomoose_globals.map it loads at the same speeds as my geomoose 2 mapfile
>> using shp2image, but it still loads slowly in
>> geomoose as it's reprojected to 3857. If I instead switch everything to
>> 3857 it loads rapidly (although in a different location as my data isn't in
>> 3857). I tested it out by reprojecting my contours dataset to 3857 and it
>> loads much faster than the dataset
>> still in our local projection.
>> Any ideas how to work around this other than reprojecting all my data or
>> changing all the files that are hard-coded as 3857? See issue:
>> https://github.com/geomoose/gm3/issues/192
>> Chris
>> On Mon, Feb 3, 2020 at 9:34 AM TC Haddad <tchaddad at gmail.com> wrote:
>>> Another thing to try is to do the reproduction in a PostGIS view, so
>>> that GeoMoose is not trying to do it in the browser...
>>> On Mon, Feb 3, 2020 at 11:40 AM Basques, Bob (CI-StPaul) <
>>> bob.basques at ci.stpaul.mn.us> wrote:
>>>> Try sending the same request you are sending in the GeoMoose 2 version
>>>> to the GeoMoose 3 version (without reprojection) and compare the speeds.
>>>> If everything else is working but just slower, it might be a result of the
>>>> reprojection overhead.
>>>> bobb
>>>> On Feb 3, 2020, at 10:18 AM, Christopher Hughes <
>>>> *Think Before You Click: *This email originated *outside *our
>>>> organization.
>>>> I'm using an older version of mapserver on this server for geomoose 2
>>>> (which is the one rendering faster).
>>>> I am reprojecting to our local coordinate system which I didn't have to
>>>> do for geomoose 2. Perhaps I have my extent coordinates wrong.
>>>> Chris
>>>> On Sun, Feb 2, 2020 at 10:54 AM Brian Fischer <bfischer at houstoneng.com>
>>>> wrote:
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Chris Hughes
>> GIS Analyst
>> Lincoln County Surveyor Department
>> 880 NE 7th
>> <https://www.google.com/maps/search/880+NE+7th?entry=gmail&source=g> St.
>> l Newport, OR 97365
>> Tel: (541) 574 1283
Chris Hughes
GIS Analyst
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200203/2adff18c/attachment-0001.html>
More information about the Geomoose-users
