[Geomoose-users] GeoMoose 3 - Select
Christopher Hughes chughes at co.lincoln.or.us
Mon Feb 3 15:41:14 PST 2020
Thanks Dan,
I got it working from that. For anyone's reference here's my full service:
        app.registerService('select-list', SelectService, {
          // set the default layers
          defaultLayer: 'Taxlots_selection-wfs/Taxlots_selection',
          fields: [{
            type: 'select',
           // specify the default layer
            default: 'Taxlots_selection-wfs/Taxlots_selection',
            // specify and label the list of layers to select
            options: [
              {value: 'Taxlots_selection-wfs/Taxlots_selection', label:
'Taxlots'},
              {value: 'surveys_selection-wfs/surveys_selection', label:
'Surveys'},
It looks like the defaultLayer parameter may not be needed, but the default
within the fields section is.
Chris
On Sun, Feb 2, 2020 at 10:15 AM Dan Little <theduckylittle at gmail.com> wrote:
> Something like this:
>   type: 'select',
>   options: [
>     {value: 'path/to/layer', label: 'SUPER LAYER'},
>     {value: ';path/tolayerB', label: 'LESS SUPER LAYER'},
> On Fri, Jan 31, 2020 at 12:27 PM Christopher Hughes <
> chughes at co.lincoln.or.us> wrote:
>> Hi Dan,
>> How would you adjust this to specify a fixed list of layers?
>> Thanks,
>> Chris
>> On Tue, Jan 28, 2020 at 11:18 AM Christopher Hughes <
>>> Thanks for these fixes! I've added these and now it looks like it's
>>> working (almost) as expected.
>>> My only question is what is the 'name: 'layer'' parameter supposed to
>>> do? Adding or removing
>>> it doesn't appear to change how the service works or looks, so I'm not
>>> entirely sure I've configured
>>> it correctly. I was hoping it would add a subheader or something so that
>>> users know what dataset
>>> they're querying. (The main reason I'm trying to do this is because for
>>> some users breaking apart
>>> the select into different tools may be more straightforward than a
>>> drop-down menu).
>>> Thanks,
>>> Chris
>>> On Mon, Jan 27, 2020 at 6:17 PM Dan Little <theduckylittle at gmail.com>
>>> wrote:
>>>> I messed up two things:
>>>> 1. It should be "fields" not "inputs".
>>>> 2. We have not properly implemented hidden fields.
>>>> Here is the fix for 1:
>>>>     app.registerService('select', SelectService, {
>>>>         defaultLayer: 'vector-parcels/parcels',
>>>>         fields: [{
>>>>             type: 'hidden',
>>>>             default: 'vector-parcels/parcels'
>>>> And the fix for 2:
>>>> - https://github.com/geomoose/gm3/pull/461
>>>> On Mon, Jan 27, 2020 at 5:27 PM Christopher Hughes <
>>>>> Thanks for the feedback.
>>>>> I'm having trouble replicating this. I'm trying to modify the demo's
>>>>> select to test it and I'm not noticing any difference in the select tool.
>>>>> Demo:
>>>>> My Attempt:
>>>>>         // remove the layer select
>>>>>         inputs: [{
>>>>>             type: 'hidden',
>>>>> The only change I'm noticing is that with this syntax, turning on
>>>>> autoGo and removing the select options incompatible with autoGo no longer
>>>>> works.
>>>>> Any suggestions?
>>>>> Thanks,
>>>>> Chris
>>>>> On Sun, Jan 26, 2020 at 1:24 PM Dan Little <theduckylittle at gmail.com>
>>>>> wrote:
>>>>>> This should be settable in app.js:
>>>>>>     app.registerService('my-other-select', SelectService, {
>>>>>>         inputs: [{
>>>>>>             type: 'hidden',
>>>>>>             default: 'source/layer'
>>>>>> This change removes the Select input and makes it a fixed field. You
>>>>>> can also specify that as a select with a fixed list of layers.
>>>>>> On Fri, Jan 10, 2020 at 3:35 PM Christopher Hughes <
>>>>>>> For geomoose 3, is there a way to specify which layers you can
>>>>>>> select rather than just setting
>>>>>>> the default layer and being able to select all layers you've set to
>>>>>>> be selectable? I'd like to create
>>>>>>> a select tool for each of the layers I want to select (like you can
>>>>>>> for searches), but if I do that now
>>>>>>> you'd still be able to switch to a different layer in the tool.
>>>>>>> Relatedly, is there a way to remove the
>>>>>>> 'Select from' dropdown box so it just uses the default layer you set
>>>>>>> in the service?
>>>>>>> Thanks,
>>>>>>> Chris
>>>>>>> Chris Hughes
>>>>>>> GIS Analyst
>>>>>>> Lincoln County Surveyor Department
>>>>>>> 880 NE 7th St. l Newport, OR 97365
>>>>>>> Tel: (541) 574 1283
>>>>>>> _______________________________________________
>>>>>>> Geomoose-users mailing list
>>>>>>> Geomoose-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>>> Chris Hughes
>>>>> GIS Analyst
>>>>> Tel: (541) 574 1283
>>> Chris Hughes
>>> GIS Analyst
>>> Tel: (541) 574 1283
>> Chris Hughes
>> GIS Analyst
>> Tel: (541) 574 1283
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200203/3046a697/attachment.html>
More information about the Geomoose-users mailing list
