[Geomoose-users] Install Geomoose
Lara Perez- Jefa Departamento Cartografia y Topografia Ayuntamiento Oliva (Valencia) Spain topografia at oliva.es
Mon Feb 3 04:18:49 PST 2020
Hi. Thank you all for the answers. Finally, I found the problem: the
projection. My information is in EPSG: 25830 (UTM ETRS89 30N). Spain. I
have read this post with problems in the projection of WFS through
Mapserver:
https://lists.osgeo.org/pipermail/mapserver-dev/2018-March/015353.html
It is supposed to be solved ... but I agree with the same. I have
changed the files app.js, parcels.map, geomoose_globlas.map and
common_metadata.map ... the information is displayed ... but in the
wrong coordinates .... The correct ones are: 750000; 4308000 for the
center of the view, and I had to place it in 1433; 4714300 to be able to
visualize it ....
Are Geomoose and Mapserver able to work with EPSG:25830?
<http://oliva.es/es/>
*Cap del Departament de Cartografia i Topografia*
Lara Perez Bessone
Enginyera Tecnica Topografa Municipal
email: topografia at oliva.es Tel. mòvil: 647 835 086 ext. 521
*Ajuntament d'Oliva - València*
Plaça del Ajuntament 1, 46780 Oliva
Tel. 962850250 Fax 962855165 www.oliva.es
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200203/4840d24a/attachment.html>
More information about the Geomoose-users mailing list
