[Geomoose-users] GeoMoose 3 - Search
Dan Little
theduckylittle at gmail.com
Thu Feb 6 15:06:56 PST 2020
Pass it in as an option on app.js.
On Thu, Feb 6, 2020, 18:04 Christopher Hughes <chughes at co.lincoln.or.us>
wrote:
> Hi Dan,
> Do you mean changing this in the search.js file or trying to overwrite
> this in app.js when creating the individual search service?
> Thanks,
> Chris
> On Wed, Feb 5, 2020 at 6:42 AM Dan Little <theduckylittle at gmail.com>
> wrote:
>> Hi Chirs,
>> You can make that happen by overriding "prepareFields" in the options.
>> This is a little rough and untested but I believe this would do it:
>> prepareFields: function(fields) {
>> var query = ['or']; // adding or to the beginning should make it
>> conditional.
>> var queryFields = ['PIN', 'NAME', 'STREETNAME'];
>> var searchValue = fields[0].value;
>> for(var i = 0, ii = queryFields.length; i < ii; i++) {
>> query.push({
>> comparitor: 'ilike',
>> value: '%' + searchValue + '%'
>> return query;
>> On Tue, Feb 4, 2020 at 3:33 PM Christopher Hughes <
>> chughes at co.lincoln.or.us> wrote:
>>> Does anyone know if there's a way to configure a search service in
>>> geomoose 3 that searches
>>> over multiple fields in a single box?
>>> I'd like to be able to configure a simple search that allows users to
>>> enter information in a single box
>>> and find results that match information in any of the fields you
>>> specify. This way they don't need to
>>> know as much about how your data is organized. My current workaround is
>>> to just create a new
>>> dataset that has all the fields I want, concatenated into a single
>>> field, and set geomoose to search
>>> that in the service. This gets the job done but I'd rather not modify
>>> the data if I don't have to.
>>> Thanks,
>>> Chris
>>> Chris Hughes
>>> GIS Analyst
>>> Lincoln County Surveyor Department
>>> 880 NE 7th St. l Newport, OR 97365
>>> Tel: (541) 574 1283
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> Chris Hughes
> GIS Analyst
> Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200206/599e74a4/attachment.html>
More information about the Geomoose-users
