[Geomoose-users] GeoMoose 3 - Search
Christopher Hughes
chughes at co.lincoln.or.us
Tue Feb 11 16:28:30 PST 2020
Hi Dan,
I'm having trouble getting this working. I've tried several combinations of
the code below. When I omit the fields parameter at the end there's no box
to input a search,
but with it I'm unsure about how to adjust it for searching multiple
fields. Depending on how what I try I either get a comparitor error or an
error saying prepareFields/queryFields
isn't defined. Do you have any ideas?
Working in the demo:
app.registerService('search', SearchService, {
prepareFields: function(fields) {
var query = ['or']; // adding or to the beginning should make it
conditional.
var queryFields = ['OWNER_NAME', 'OWN_ADD_L1', 'OWN_ADD_L3'];
var searchValue = fields[0].value;
for(var i = 0, ii = queryFields.length; i < ii; i++) {
query.push({
comparitor: 'ilike',
value: '%' + searchValue + '%'
return query;
fields: [
{type: 'text', label: 'City/State/ZIP', name: 'prepareFields'}
searchLayers: ['vector-parcels/parcels']
Thanks,
Chris
On Thu, Feb 6, 2020 at 3:07 PM Dan Little <theduckylittle at gmail.com> wrote:
> Pass it in as an option on app.js.
> On Thu, Feb 6, 2020, 18:04 Christopher Hughes <chughes at co.lincoln.or.us>
> wrote:
>> Hi Dan,
>> Do you mean changing this in the search.js file or trying to overwrite
>> this in app.js when creating the individual search service?
>> Thanks,
>> Chris
>> On Wed, Feb 5, 2020 at 6:42 AM Dan Little <theduckylittle at gmail.com>
>> wrote:
>>> Hi Chirs,
>>> You can make that happen by overriding "prepareFields" in the options.
>>> This is a little rough and untested but I believe this would do it:
>>> conditional.
>>> var queryFields = ['PIN', 'NAME', 'STREETNAME'];
>>> query.push({
>>> return query;
>>> On Tue, Feb 4, 2020 at 3:33 PM Christopher Hughes <
>>> chughes at co.lincoln.or.us> wrote:
>>>> Does anyone know if there's a way to configure a search service in
>>>> geomoose 3 that searches
>>>> over multiple fields in a single box?
>>>> I'd like to be able to configure a simple search that allows users to
>>>> enter information in a single box
>>>> and find results that match information in any of the fields you
>>>> specify. This way they don't need to
>>>> know as much about how your data is organized. My current workaround is
>>>> to just create a new
>>>> dataset that has all the fields I want, concatenated into a single
>>>> field, and set geomoose to search
>>>> that in the service. This gets the job done but I'd rather not modify
>>>> the data if I don't have to.
>>>> Thanks,
>>>> Chris
>>>> Chris Hughes
>>>> GIS Analyst
>>>> Lincoln County Surveyor Department
>>>> 880 NE 7th St. l Newport, OR 97365
>>>> Tel: (541) 574 1283
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Chris Hughes
>> GIS Analyst
>> Tel: (541) 574 1283
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200211/867e7a67/attachment.html>
More information about the Geomoose-users
