[Geomoose-users] Geomoose 3, URL call to start a service with parameters
Christopher Hughes
chughes at co.lincoln.or.us
Wed Jun 10 08:57:25 PDT 2020
Brent,
That was exactly what I was referring to, thanks! It definitely helps
knowing what that zoom/resolution parameter is
referring to. Now to figure out how to programmatically reproduce it.
On Wed, Jun 10, 2020 at 8:39 AM TC Haddad <tchaddad at gmail.com> wrote:
> +1 for some clarity or examples on how to do this.
> It seems related to bookmarking, which is discussed in this old issue:
> https://github.com/geomoose/gm3/issues/66
> On Wed, Jun 10, 2020 at 8:28 AM Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Chris,
>> The "loc" hash parameter in the url has a resolution value (not quite
>> the
>> same zoom but close):
>> loc=50;-10321714;5584217
>> would be: zoom to 50m./pixel, center map at X=-10321714 Y=5584217
>> Or did you mean something else?
>> Brent
>> -------- Original Message --------
>> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>> > Sent: June 10, 2020 9:18 AM
>> > To: "Eli Adam" <eadam at co.lincoln.or.us>
>> > Cc: "geomoose-users-osgeo" <geomoose-users at lists.osgeo.org>
>> > Subject: Re: [Geomoose-users] Geomoose 3,URL call to start a service
>> with
>> parameters
>> > Does anyone know how the zoom parameter is determined in the url?
>> > We have a similar situation where we have a dataset of links to each
>> parcel
>> > that specify a bounding box
>> > (rather than GeoMoose 3's zoom and point). Converting these to web
>> mercator
>> > isn't much of an issue
>> > (or finding parcel centroids in web mercator), but I haven't figured out
>> > how to programmatically create
>> > URL's that include a zoom and a point parameter.
>> > Chris
>> > On Tue, Jun 9, 2020 at 7:41 AM Eli Adam <eadam at co.lincoln.or.us> wrote:
>> > > Hi Michael,
>> > > On Tue, Jun 9, 2020 at 5:13 AM Reynolds, Michael J. (MNIT)
>> > > <mike.reynolds at state.mn.us> wrote:
>> > > > Is there a way to call a service or action by using a url
>> parameter?
>> If
>> > > not, in the app.js could I inspect the URL parameters and if I see a
>> > > particular parameter name (for example "service"), initiate a service
>> after
>> > > the app loads?
>> > > You can run services at startup,
>> > > https://geomoose.github.io/gm3/howto/start-a-service.html
>> > > https://github.com/geomoose/gm3/issues/455
>> > > Best regards, Eli
>> > > > We've got user cases where users have Latitutde Longitude (WGS84)
>> for
>> > > locations which they would like to pass to a Geomoose URL as
>> parameters
>> to
>> > > go to that location directly. Users have noticed the coordinate values
>> > > inherent in a Geomoose url but converting from WGS84 to web mercator
>> is
>> an
>> > > extra step.
>> > > > Any tips appreciated.
>> > > > Michael Reynolds
>> > > > Application Support | Application Portfolio Management (APM)
>> > > > Minnesota IT Services | Partnering with MnDOT
>> > > > 359 John Ireland Blvd.
>> > > > St. Paul, MN 55155
>> > > > O: 651-366-4918
>> > > > Information Technology for Minnesota Government | mn.gov/mnit
>> > > > _______________________________________________
>> > > > Geomoose-users mailing list
>> > > > Geomoose-users at lists.osgeo.org
>> > > > https://lists.osgeo.org/mailman/listinfo/geomoose-users
>> > Chris Hughes
>> > GIS Analyst
>> > Lincoln County Surveyor Department
>> > 880 NE 7th St. l Newport, OR 97365
>> > Tel: (541) 574 1283
>> > _______________________________________________ Geomoose-users mailing
>> list Geomoose-users at lists.osgeo.org
Chris Hughes
GIS Analyst
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200610/9780f15b/attachment-0001.html>
More information about the Geomoose-users
