[Geomoose-users] Geomoose 3, URL call to start a service with parameters
TC Haddad tchaddad at gmail.com
Wed Jun 10 08:39:29 PDT 2020
+1 for some clarity or examples on how to do this.
It seems related to bookmarking, which is discussed in this old issue:
https://github.com/geomoose/gm3/issues/66
On Wed, Jun 10, 2020 at 8:28 AM Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Chris,
>  The "loc" hash parameter in the url has a resolution value (not quite the
> same zoom but close):
>  loc=50;-10321714;5584217
>  would be:  zoom to 50m./pixel, center map at X=-10321714 Y=5584217
>  Or did you mean something else?
>  Brent
>  -------- Original Message --------
> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
> > Sent: June 10, 2020 9:18 AM
> > To: "Eli Adam" <eadam at co.lincoln.or.us>
> > Cc: "geomoose-users-osgeo" <geomoose-users at lists.osgeo.org>
> > Subject: Re: [Geomoose-users] Geomoose 3,URL call to start a service
> with
> parameters
> > Does anyone know how the zoom parameter is determined in the url?
> > We have a similar situation where we have a dataset of links to each
> parcel
> > that specify a bounding box
> > (rather than GeoMoose 3's zoom and point). Converting these to web
> mercator
> > isn't much of an issue
> > (or finding parcel centroids in web mercator), but I haven't figured out
> > how to programmatically create
> > URL's that include a zoom and a point parameter.
> > Chris
> > On Tue, Jun 9, 2020 at 7:41 AM Eli Adam <eadam at co.lincoln.or.us> wrote:
> > > Hi Michael,
> > > On Tue, Jun 9, 2020 at 5:13 AM Reynolds, Michael J. (MNIT)
> > > <mike.reynolds at state.mn.us> wrote:
> > > > Is there a way to call a service or action by using a url parameter?
> If
> > > not, in the app.js could I inspect the URL parameters and if I see a
> > > particular parameter name (for example "service"), initiate a service
> after
> > > the app loads?
> > > You can run services at startup,
> > > https://geomoose.github.io/gm3/howto/start-a-service.html
> > > https://github.com/geomoose/gm3/issues/455
> > > Best regards, Eli
> > > > We've got user cases where users have Latitutde Longitude (WGS84)
> for
> > > locations which they would like to pass to a Geomoose URL as
> parameters
> to
> > > go to that location directly. Users have noticed the coordinate values
> > > inherent in a Geomoose url but converting from WGS84 to web mercator
> is
> an
> > > extra step.
> > > > Any tips appreciated.
> > > > Michael Reynolds
> > > > Application Support | Application Portfolio Management (APM)
> > > > Minnesota IT Services | Partnering with MnDOT
> > > > 359 John Ireland Blvd.
> > > > St. Paul, MN 55155
> > > > O: 651-366-4918
> > > > Information Technology for Minnesota Government | mn.gov/mnit
> > > > _______________________________________________
> > > > Geomoose-users mailing list
> > > > Geomoose-users at lists.osgeo.org
> > > > https://lists.osgeo.org/mailman/listinfo/geomoose-users
> > Chris Hughes
> > GIS Analyst
> > Lincoln County Surveyor Department
> > 880 NE 7th St. l Newport, OR 97365
> > Tel: (541) 574 1283
> > _______________________________________________ Geomoose-users mailing
> list Geomoose-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200610/0a78f1a7/attachment.html>
More information about the Geomoose-users mailing list
