[Geomoose-users] Geomoose 3, URL call to start a service with parameters
Brent Fraser
bfraser at GeoAnalytic.com
Wed Jun 10 08:23:24 PDT 2020
Chris,
The "loc" hash parameter in the url has a resolution value (not quite the
same zoom but close):
loc=50;-10321714;5584217
would be: zoom to 50m./pixel, center map at X=-10321714 Y=5584217
Or did you mean something else?
Brent
-------- Original Message --------
> From: "Christopher Hughes" <chughes at co.lincoln.or.us>
> Sent: June 10, 2020 9:18 AM
> To: "Eli Adam" <eadam at co.lincoln.or.us>
> Cc: "geomoose-users-osgeo" <geomoose-users at lists.osgeo.org>
> Subject: Re: [Geomoose-users] Geomoose 3,URL call to start a service with
parameters
> Does anyone know how the zoom parameter is determined in the url?
> We have a similar situation where we have a dataset of links to each
parcel
> that specify a bounding box
> (rather than GeoMoose 3's zoom and point). Converting these to web
mercator
> isn't much of an issue
> (or finding parcel centroids in web mercator), but I haven't figured out
> how to programmatically create
> URL's that include a zoom and a point parameter.
> Chris
> On Tue, Jun 9, 2020 at 7:41 AM Eli Adam <eadam at co.lincoln.or.us> wrote:
> > Hi Michael,
> > On Tue, Jun 9, 2020 at 5:13 AM Reynolds, Michael J. (MNIT)
> > <mike.reynolds at state.mn.us> wrote:
> > > Is there a way to call a service or action by using a url parameter?
If
> > not, in the app.js could I inspect the URL parameters and if I see a
> > particular parameter name (for example "service"), initiate a service
after
> > the app loads?
> > You can run services at startup,
> > https://geomoose.github.io/gm3/howto/start-a-service.html
> > https://github.com/geomoose/gm3/issues/455
> > Best regards, Eli
> > > We've got user cases where users have Latitutde Longitude (WGS84)
for
> > locations which they would like to pass to a Geomoose URL as parameters
to
> > go to that location directly. Users have noticed the coordinate values
> > inherent in a Geomoose url but converting from WGS84 to web mercator is
an
> > extra step.
> > > Any tips appreciated.
> > > Michael Reynolds
> > > Application Support | Application Portfolio Management (APM)
> > > Minnesota IT Services | Partnering with MnDOT
> > > 359 John Ireland Blvd.
> > > St. Paul, MN 55155
> > > O: 651-366-4918
> > > Information Technology for Minnesota Government | mn.gov/mnit
> > > _______________________________________________
> > > Geomoose-users mailing list
> > > Geomoose-users at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geomoose-users
> Chris Hughes
> GIS Analyst
> Lincoln County Surveyor Department
> 880 NE 7th St. l Newport, OR 97365
> Tel: (541) 574 1283
> _______________________________________________ Geomoose-users mailing
list Geomoose-users at lists.osgeo.org
More information about the Geomoose-users
