[Geomoose-users] GM3 - Error building on current clone
James Klassen klassen.js at gmail.com
Mon Jun 29 13:09:43 PDT 2020
I can merge the two PRs but I haven't had time to properly look them over
yet.  But at the same time, if master is broken anyway, what can it hurt?
On Mon, Jun 29, 2020, 15:01 Christopher Hughes <chughes at co.lincoln.or.us>
wrote:
> Awesome thanks! Glad to hear it's a known issue with a fix in the works.
> Brent, I'll try your suggestion in the meantime.
> Chris
> On Mon, Jun 29, 2020 at 11:53 AM Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Hi Chris,
>>     I think the fault is mine with a poorly tested code change.  Dan has
>> a
>> pull request pending that will fix the issues, but in the mean time you
>> can
>> simple change lines 501 and 523 to fix the two errors:
>>  501: delete the comment:  " // for lines..."
>>  523: change the
>>      != 200
>>  to
>>     !== 200
>>  Best Regards,
>>  Brent Fraser
>>  -------- Original Message --------
>> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>> > Sent: June 29, 2020 12:43 PM
>> > To: "GeoMoose Users" <geomoose-users at lists.osgeo.org>
>> > Subject: [Geomoose-users] GM3 - Error building on current clone
>> > Hello,
>> > I'm having a new issue rebuilding the geomoose javascript on windows per
>> > https://geomoose.github.io/gm3/install_on_windows.html
>> > I'm building on a current clone of geomoose 3, so the package-lock.json
>> > file should be up to date with the repo. After cloning
>> > and running 'npm install'; running 'npm run build' fails. I've tried
>> > deleting the node_modules directory and re-running npm install
>> > without success. I haven't made any changes to my clone of the repo.
>> > I've included some of the relevant errors below:
>> > [image: image.png]
>> > Any tips would be appreciated!
>> > Chris
>> > Chris Hughes
>> > GIS Analyst
>> > Lincoln County Surveyor Department
>> > 880 NE 7th St. l Newport, OR 97365
>> > Tel: (541) 574 1283
>> > _______________________________________________ Geomoose-users mailing
>> list Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> Chris Hughes
> GIS Analyst
> Tel: (541) 574 1283
> Geomoose-users mailing list
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200629/e2cf6a5c/attachment.html>
More information about the Geomoose-users mailing list
