[Geomoose-users] GM3 - Error building on current clone
James Klassen klassen.js at gmail.com
Mon Jun 29 13:11:09 PDT 2020
I did look at cherry-picking the one commit from #558 but it appears to do
more than is on the label, so I was worried that would break things more.
On Mon, Jun 29, 2020, 15:09 James Klassen <klassen.js at gmail.com> wrote:
> I can merge the two PRs but I haven't had time to properly look them over
> yet.  But at the same time, if master is broken anyway, what can it hurt?
> On Mon, Jun 29, 2020, 15:01 Christopher Hughes <chughes at co.lincoln.or.us>
> wrote:
>> Awesome thanks! Glad to hear it's a known issue with a fix in the works.
>> Brent, I'll try your suggestion in the meantime.
>> Chris
>> On Mon, Jun 29, 2020 at 11:53 AM Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> Hi Chris,
>>>     I think the fault is mine with a poorly tested code change.  Dan has
>>> a
>>> pull request pending that will fix the issues, but in the mean time you
>>> can
>>> simple change lines 501 and 523 to fix the two errors:
>>>  501: delete the comment:  " // for lines..."
>>>  523: change the
>>>      != 200
>>>  to
>>>     !== 200
>>>  Best Regards,
>>>  Brent Fraser
>>>  -------- Original Message --------
>>> > From: "Christopher Hughes" <chughes at co.lincoln.or.us>
>>> > Sent: June 29, 2020 12:43 PM
>>> > To: "GeoMoose Users" <geomoose-users at lists.osgeo.org>
>>> > Subject: [Geomoose-users] GM3 - Error building on current clone
>>> > Hello,
>>> > I'm having a new issue rebuilding the geomoose javascript on windows
>>> per
>>> > https://geomoose.github.io/gm3/install_on_windows.html
>>> > I'm building on a current clone of geomoose 3, so the package-lock.json
>>> > file should be up to date with the repo. After cloning
>>> > and running 'npm install'; running 'npm run build' fails. I've tried
>>> > deleting the node_modules directory and re-running npm install
>>> > without success. I haven't made any changes to my clone of the repo.
>>> > I've included some of the relevant errors below:
>>> > [image: image.png]
>>> > Any tips would be appreciated!
>>> > Chris
>>> > Chris Hughes
>>> > GIS Analyst
>>> > Lincoln County Surveyor Department
>>> > 880 NE 7th St. l Newport, OR 97365
>>> > Tel: (541) 574 1283
>>> > _______________________________________________ Geomoose-users mailing
>>> list Geomoose-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Chris Hughes
>> GIS Analyst
>> Tel: (541) 574 1283
>> Geomoose-users mailing list
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200629/8746828e/attachment-0001.html>
More information about the Geomoose-users mailing list
